Pin out is as such on the bottom:
Very bottom yellow - bridges the bat and vio pins on the FONA
next up yellow - connects bat on FONA to + positive on the power board JST
top horizontal yellow - connects the gnd from FONA to power board gnd
vertical yellow - connects the power board output back down to the gnd power rail
vertical green - connects the power board output down to the + rail
vertical right green - connects Pi RX to FONA TX
vertical orange - connects Pi TX to FONA RX
Oh and cant forget, i black taped a fat 2000mah 3.7 battery to the bottom of my A+. add an hdmi screen and use it like that or add a wifi dongle and use it as a Pivot box.
matt venn
Patrick Van Oosterwijck
Nicholas Hill
Curious if the SIM card situation was handled and how the SSH reverse shell worked out?
