Cheap-dirty-perfect V-Groove Foam Cutter / Bender
A tool made in 15 minutes that will help you cut perfect V-Groove in polystyrene foam. The groove will help bend the foam.
I generally spend more time designing and making the tools I need for a work than I spend using them for the given work. This time, I made a quick and dirty tool in 15 minutes, that still gives a perfect result.
  • 1 × Wooden bar at least 40x25mm, 50x30 would be better
  • 1 × Wooden bar 2 (optionnal) 8x20mm would be fined. I used cheap solid oak wooden floor. You can also cut that from the first bar.
  • 1 × Wooden glue I did not have some, so I used cyanoacrylate (superglue)
  • 2 × Razor blades
  • 1 × Adhesive tape I used both large brown packing tape and normal transparent adhesive tape.
View all 7 components
  • Nothing to blog !
    ftregan • 03/05/2015 at 09:44 • 0 comments
    It took less than one hour from the idea to the second build I made (I made a second build so I can take pictures to document it). Nothing to blog, but the result is exactly what I wanted: cheap, made with thing I hade available here, it solves the problem with a perfect result.
View project log
  • 1
    Step 1
    Cut the first piece of wood
    Cut a 60 to 80mm long piece of the first bar of wood (the 35x50mm one), the cut it at 45° across the middle of the 35x60mm side
  • 2
    Step 2
    Flip one of the pieces
    Your cut is probably not perfectly perpendicular to the side of the bar (remember: this a quick and dirty build), and then the edges are far from being parallel when you align the pieces:
    But remember, this is also a perfect build. So flip one of the pieces to correct the problem:
    (Thank you God Of Geometry)
  • 3
    Step 3
    Glue
    The space between two pieces of wood must be equal to the width of the groove, that is twice the depth of the groove for a 45° cut. (I want to make a V Groove in 6mm foam, so the groove will be 4mm depth and 8mm wide).
View all 13 instructions
