Here are links to download custom parts:
STL files for 3D printing (untested, but I bet it would work fine)
http://s000.tinyupload.com/index.php?file_id=09098959973777174112
STEP files for machining or import into CAD for mods:
http://s000.tinyupload.com/index.php?file_id=00751233921801579441
Notes:
- The arbor press I used has a 1.5" x 1.5" square ram, this may be different on your arbor press and will require a tweak to the design.
- You will need a #4-40 tap to add the threads necessary to assemble the parts.
- For consistent press depth, install a shaft clamp to the top of your arbor press ram and clamp it down where you want the press to stop its downward travel. I have linked to a shaft clamp in my components list. Make sure you get the right size for your arbor press though.
Alex Rich
Yibo Fan
Quinn
Scott
Hey Alex,
I'm interested in building something like this, but the files are gone from the links you provided. Can you upload them to the project files section?
