My project for robotics class. Have an old ORT- Armdroid robot arm from the 80's. No controller or software.
Got to work last night reviving this little arm. Removed the original circuit board, a nice piece of work.
Next, I set out and build a stepper motor driver using a 555 for clock, 74194 shift register, 7404 driver inverter, and TIP120s.
I then moved each joint independently, and woke the little guy up.
View project log
Mihai Oltean
Shawn Chen
Justin Maynard
dannyvandenheuvel
Yes, delete it Cancel
You are about to report the project "ORT- Armdroid Robot Arm", please tell us the reason.
