• Coil test photo
    jay-t07/02/2015 at 23:47 0 comments
    I updated the gallery with my first test coil winded on a biro with magnet inside.
    I hooked it to my oscilloscope to check if it works.
    TODO: wind a better coil with more windings and check the voltage coming out.
  • First test
    jay-t04/04/2015 at 03:48 0 comments
    I winded a coil on a biro tube. The coil is about a meter wire. I get 0.7 volts measured with my oscilloscope using a 8 x 10 mm neodym magnet inside.
    I have to find a tube which has an inner width of about 9 mm and wind a more thicker coil around it to get more volts.
  • Magnets ordered
    jay-t03/29/2015 at 19:17 0 comments
    Today I ordered cylindrical magnets to experiment with. Now I have to find a plastic tube in which they fit. Then I can do some tests with the magnets and coils.
