Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Laser Cutter 300mW
Two Stepper Motors. One arduino. Adventure. Explosions. Maaan, 140 char is hard. Hardware.
Tiago DamianTiago Damian
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.3k views
3 comments
25 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
2.3k
3
25
7
Team (1)
  • Tiago DamianTiago Damian
Join this project's team
  • Jenslabs
  • Derfrickler
  • LaserBlade Darkly Labs
hardware
ongoing project
laser CNC arduino GRBL
Related lists
DIY CNC milling machine
milling machine
This project was created on 04/13/2015 and last updated 6 years ago.
Description
A CNC XY-table used with a DVD recorder Laser. Based on http://jenslabs.com/2013/12/16/what-can-you-cut-with-a-300mw-diy-laser-cutter/ .
Components
  • 1 × Arduino
  • 2 × Easy Driver
  • 2 × Stepper Motor
  • 3 × Drawer Slider
  • 1 × PC Power Supply
View all 6 components
Project Logs
Collapse
  • Project relocation & acrilic control panel
    Tiago Damian • 05/05/2015 at 17:18 • 0 comments
  • Soldering Easy Driver
    Tiago Damian • 04/26/2015 at 19:39 • 0 comments
    Easy Driver Arrived.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
George I Fomitchev wrote 06/25/2017 at 20:38 • point
awesome, if you consider to add more powerful laser, you may try Endurance lasers... they are very user-friendly for that!
esot.eric wrote 05/19/2015 at 14:00 • point
The tag-line is awesome.
Tiago Damian wrote 05/19/2015 at 14:25 • point
ahhaha. thank you man.
Ready-to-assemble DIY desktop laser cutter and engraver developed by smartDIYs, Japanese engineers.
Project Owner Contributor
Open source Desktop Laser Cutter Engraver
smartDIYssmartDIYs
Using an Arduino and a pair of servos to create a laser show on a sheet of luminous vinyl.
Laser Galvo: Arduino Controlled
robivesrobives
Draw patterns on the surface of a table using glow-in-the-dark paint and a laser pointer.
Laser Table
Ben WienerBen Wiener
The 2017 Hackaday Prize
I built a laser piano using LDRs and laser light diodes. I used an Arduino Leonardo Pro Micro connected to a speaker to generate sound
DIY Laser Piano
vivek guptavivek gupta
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "Laser Cutter 300mW", please tell us the reason.
Send message
Remove Member
