Led Code Used In Example
05/12/2015 at 17:39 • 0 comments#include <Adafruit_NeoPixel.h> #define PIN 2 //pin 2 on teensy shield #define LEDS 15 //number of leds total // Based on Adafruit Neopixel example https://github.com/adafruit/Adafruit_NeoPixel // Parameter 12 = number of pixels in strip // Parameter 2 = pin number (most are valid) // Parameter 3 = pixel type flags, add together as needed: // NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs) // NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers) // NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products) // NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2) Adafruit_NeoPixel strip = Adafruit_NeoPixel(15, PIN, NEO_RGB + NEO_KHZ800); //NEO_GRB as below colors show void setup() { strip.begin(); strip.show(); // Initialize all pixels to 'off' } int fademax = 10; int fadeouts[10] = { 0, 0, 0, 0, 0, 1, 4, 16, 64, 255 }; // of number of fasouts int fadelevels[LEDS] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11}; // of number leds int scancount = 29; int scanpos[29] = { 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0 }; // of number of scan positions void loop() { // Some example procedures showing how to display to the pixels: for(int i=0; i<scancount; i++) { fadelevels[scanpos[i]] = fademax + 1; fadeout(); delay(150); //speed of travel } } void fadeout() { for (int i=0; i<LEDS; i++) { if (fadelevels[i] > 0) fadelevels[i]--; int level = fadeouts[fadelevels[i]]; // uint32_t c = strip.Color(level, 0, level / 2); // GRB Pink OR RGB baby blue // uint32_t c = strip.Color(level, level, level); // GRB White OR RGB white // uint32_t c = strip.Color(level, 2, level / 4); // GRB green + pink OR RGB blue + red // uint32_t c = strip.Color(level, 0, level / 1); // GRB light purple OR RGB med blue // uint32_t c = strip.Color(level, 3, level / 255); // GRB green + red OR RGB Red + green uint32_t c = strip.Color(level, 0, level / 60); // GRB red OR RGB green // uint32_t c = strip.Color(100, 10, level / 3); // RGB all green + Blue fade // uint32_t c = strip.Color(1, 10, level / 3); // RGB all RED + blue fade strip.setPixelColor(i, c); } strip.show(); } // Input a value 0 to 255 to get a color value. // The colours are a transition r - g - b - back to r. uint32_t Wheel(byte WheelPos) { if(WheelPos < 85) { return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0); } else if(WheelPos < 170) { WheelPos -= 85; return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3); } else { WheelPos -= 170; return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3); } } -
S.Port Example code
05/12/2015 at 17:35 • 0 comments/* FrSky S-Port Telemetry library example (c) Pawelsky 20141120 Not for commercial use Note that you need Teensy 3.x or 328P based (e.g. Pro Mini, Nano, Uno) board and FrSkySportTelemetry library for this example to work */ #include "FrSkySportSensor.h" #include "FrSkySportSensorFcs.h" #include "FrSkySportSensorFlvss.h" #include "FrSkySportSensorGps.h" #include "FrSkySportSensorRpm.h" #include "FrSkySportSensorVario.h" #include "FrSkySportSingleWireSerial.h" #include "FrSkySportTelemetry.h" #if !defined(__MK20DX128__) && !defined(__MK20DX256__) #include "SoftwareSerial.h" #endif FrSkySportSensorFcs fcs; // Create FCS sensor with default ID FrSkySportSensorFlvss flvss1; // Create FLVSS sensor with default ID FrSkySportSensorFlvss flvss2(FrSkySportSensor::ID15); // Create FLVSS sensor with given ID FrSkySportSensorGps gps; // Create GPS sensor with default ID FrSkySportSensorRpm rpm; // Create RPM sensor with default ID FrSkySportSensorVario vario; // Create Variometer sensor with default ID FrSkySportTelemetry telemetry; // Create Variometer telemetry object void setup() { // Configure the telemetry serial port and sensors (remember to use & to specify a pointer to sensor) #if defined(__MK20DX128__) || defined(__MK20DX256__) telemetry.begin(FrSkySportSingleWireSerial::SERIAL_3, &fcs, &flvss1, &flvss2, &gps, &rpm, &vario); #else telemetry.begin(FrSkySportSingleWireSerial::SOFT_SERIAL_PIN_12, &fcs, &flvss1, &flvss2, &gps, &rpm, &vario); #endif } void loop() { // Set current/voltage sensor (FCS) data // (set Voltage source to FAS in menu to use this data for battery voltage, // set Current source to FAS in menu to use this data for current readins) fcs.setData(25.3, // Current consumption in amps 12.6); // Battery voltage in volts // Set LiPo voltage sensor (FLVSS) data (we use two sensors to simulate 8S battery // (set Voltage source to Cells in menu to use this data for battery voltage) flvss1.setData(4.07, 4.08, 4.09, 4.10, 4.11, 4.12); // Cell voltages in volts (cells 1-6) flvss2.setData(4.13, 4.14); // Cell voltages in volts (cells 7-8) // Set GPS data gps.setData(48.858289, 2.294502, // Latitude and longitude in degrees decimal (positive for N/E, negative for S/W) 245.5, // Altitude in m (can be nevative) 100.0, // Speed in m/s 90.23, // Course over ground in degrees 14, 9, 14, // Date (year - 2000, month, day) 12, 00, 00); // Time (hour, minute, second) - will be affected by timezone setings in your radio // Set RPM/temperature sensor data // (set number of blades to 2 in telemetry menu to get correct rpm value) rpm.setData(200, // Rotations per minute 25.6, // Temperature #1 in degrees Celsuis (can be negative) -7.8); // Temperature #1 in degrees Celsuis (can be negative) // Set variometer data // (set Variometer source to VSpd in menu to use the vertical speed data from this sensor for variometer). vario.setData(250.5, // Altitude in Meters (can be negative) -1.5); // Vertical speed in m/s (positive - up, negative - down) // Send the telemetry data, note that the data will only be sent for sensors // that are being polled at given moment telemetry.send(); }
Charles Lakins
