This project is more of an analysis of work done to use an 8-bit PIC micro-controller as a synchronous buck controller. While implemented using a PIC, other controllers could be used. The PDF in the files section contains the analysis.
The design is validated in a related project here: 5V, 25W, Synchronous Buck for 12V Systems. It contains everything you need to build a working PS.
