Low Cost NFT Hydroponic Garden (under $250)
A low cost NFT hydroponic garden design cheaper than most online kit solutions. Developed as a test bed for HydroPWNics
Low Cost NFT Hydroponic garden is a cost effective design for a nutrient film technique style hydroponic grow system. The focus has mostly been using parts that are sourceable from a hardware store with minimal parts sourced from online. This design incorporates PVC pipes, fittings, PVC fencepost, and standard building lumber for a very lo cost. This project was born out of the HydroPWNics garden controller project, it was developed as test bed for the HydroPWNics hardware software system. The design turned out so well that it made sense to give it its own project page, this rig can be build as a manual NFT setup or an autonomous one incorporating HydroPWNics.
Abstract
Low Cost NFT Hydroponic Garden is a low cost nurtrient film technicque based hyrdoponics grow system. (More on NFT https://en.wikipedia.org/wiki/Nutrient_film_technique) The project is designed mostly out of parts available from a standard hardware store using standard building supplies, building lumber, fence post, and PVC pipes. Only a few specialty components have been sourced online. The idea behind this sort of design is low cost and high accessibility to anyone who wants to build one of their own. This design was originally devised as a test bed for the HydroPWNics project but ended up being worthy of its own project page.
Specifications:
- 16 Grow Sites - 3" netted pots
- 4 rows - PVC Fencepost construction
- 17 Gallon Reservoir - plastic box
- Constantly circulating
- Lowe water usage
- High efficiency
  • 2 × 5X5" Fence Post 10FT http://www.lowes.com/pd_17708-73428-73013947___?productId=4009495&pl=1&Ntt=5x5+fence+post
  • 8 × 5X5" Fence Post Top http://www.lowes.com/pd_87410-73428-73013955___?productId=4062631&pl=1&Ntt=5x5+fence+post
  • 4 × 2X4 Stud 92 5/8" http://www.lowes.com/pd_6003-99899-SG2408SPF_0__?productId=3604676&Ntt=
  • 2 × 2X6 96in http://www.lowes.com/pd_432484-42597-WF206TOPCHC08___?productId=4082904&pl=1&Ntt=2x6x8
  • 2 × 4X4 96in http://www.lowes.com/pd_4023-99899-528298_1z13cih__?productId=3606730&pl=1&Ntt=4x4
View all 21 components
  • Water Circulation Test!
    STEAL-THIS-HARDWARE09/13/2015 at 20:26 0 comments
    Before getting too excited and moving all my cramped plants into the new grow system I decided to conduct a test of the pump circulation system. I wanted to make sure the pump I am using can handle pumping from the reservoir into the input manifold. Setting up the NFT system with water for the first time is sort of a process, first I'll talk about the setup/function and what I found out about my chosen design.
    The setup as left after the silicone sealing of the end caps. It was good it was still mostly dismantled, installing the reservoir in place beneath the until requires lifting the frame, its a lot easier with everything removed.
    Flow rate sensor removed from pump tubing assembly and installed to the input manifold. The fitting on the end of the flow rate sensor adapts from 1/2" threads to a 1/2" barbed end for attaching to the tubing on the submersible pump.
    To get things started I began with setting up the reservoir internally, an airstone in each corner almost and the pump centered in the middle, secured to the bottom with suction cup feat. The tubing for the airstones, pump power cord, and pump tube all fit through the same hole in the top.
    Next I filled the reservoir with 5 gallons of water, everything inside got swished around.Later a better method for securing the pump and airstones will have to be worked out, possible using silicone as a glue to secure the tubing in place on the bottom. The reservoir has to be filled before hand at the moment since there isn't an input pipe yet, later I plan to add another 1 1/4 " pipe for adding more water/nutrients/boosters to the reservoir.
    Next I slid the reservoir beneath the frame. Since the drain manifold is built into the frame the frame needs to be lifted up to slide the reservoir underneath.
    Reservoir installed into place, with the drain manifold exit protruding directly through the hole cut for it on the top of the reservoir.
    All four fence post grow rows installed into place after installing the reservoir. The next step was installing the input manifold and connecting it to the pump. After the input manifold was in place, valves on 3 of the four rows were closed before starting the pump, each row disabled at the start were enabled one at a time starting after the first row was filled and running into the drain manifold.
    Water inside the first two rows
    Close up of the water draining into the drain manifold on one of the rows.
    After attempting to get all four rows filled with water, I discovered a problem. It seemed the pump was too weak to pump the water into the manifold. After some investigation and testing different rows by opening and closing the valves, I determined that the pump only has enough power to run half the system. A larger pump will be needed to get the system up and running but its not the end of the world.
    Additionally I wanted to test the reservoir pump out valve. This vale in the middle of the system is for using the reservoir's internal submersible pump as sort of a sump pump to drain out the reservoir into a bucket. The reason for this feature is for changing out water in the system if it get too dirty, the unit needs cleaning, etc for whatever reason you'd want to remove the water really. The whole idea is to make it easy and semi automated by using the same pump inside the reservoir and turning some valves. In order to use it the pump must be turned off, next the valves on each row need to be completely closed, finally the drain valve can be opened. The pump gets turned back on and pumps until the reservoir is empty.
    Back to the topic of the pump being undersized. The mistake made with the pump choice comes down to a few things. Submersible pumps are rated in a height they can pump this is called the total dynamic head, this rating pertains to the vertical height the pump must move the fluid. The total dynamic head is also influenced by the design of the pipe fixture it is pumping into, in the case of the input manifold, also most total dynamic head ratings assume...
  • Manifold Gluing
    STEAL-THIS-HARDWARE09/13/2015 at 08:40 0 comments
    This week I glued the manifolds for pumping and draining water through the NFT system.
    Dry press fit the drain manifold in place, Input manifold in pieces.
    Input manifold dry fit together.
    Drain manifold gluing process, the manifold is assembled within the frame, it gets permanently installed this way but it adds rigidity to the system and serves to lock the fence post grow rows in place.
    One side assembled
    Midway assembling second side of drain manifold.
    Another view
    Second half of manifold completely assembled.
    Another view of the completed manifold
    View from beneath, all four drains from the fence post rows converge to this output, it protrudes about an inch into the reservoir.
    Another view from below
    A view from the side below.
    Fence Post Grow Rows installed, they just press fit in place
    The gluing of the input manifold was a longer more careful process. The input manifold has PVC ball valves for setting the water depth in each row, I decided to assemble the manifold in stages to prevent PVC cement vapor from damaging the valves. As I assembled the manifold I made sure to take down all the lengths of the different pieces of pipe, I will be updating the other project page with this information so anyone out there can build one like mine. Moving on with the photos:
    Assembling the t-joining piece
    Assembling valve sections of the manifolds. For assembly the manifold was assembled in half essentially, pairing two fence post rows together. Each side of the manifold was assembled separately, with the idea of being installed into place and joined together with the T shaped piece above. This piece is dry assembled here and not yet glued.
    Part of section without valves assembled first. The valves and the pipe for connecting them to the fenceposts were assembled separately.
    This piece connects the pump and flow rate sensor to the manifold.
    Fitting assembly for connecting flow meter to pump and input pipe glued together.
    Gluing one of the manifold halves.
    Small sections of pipe glued to valves and set to dry, these were attached before gluing the valves into the manifold sections so they would dry a bit before hand to prevent excess vapor of the cement from melting the internals of the valve. Also picture are the two sides of the manifold that the valves glue onto and the fitting assembly for atting the pump and flow meter to the input pipe.
    Beginning the input pipe gluing. the input pipe connects the pump inside the reservoir to the T-shape piece designed to join the two halves of the manifold containing the water level set valves.
    Input pipe assembly components primed for gluing.
    Input pipe assembly in the process of being glued.
    Input pipe and T-shape (joins both sides of manifold) glued and drying for next step.
    T-shape piece and input pipe glued together.
    Manifold pieces glued in sections, set up to dry briefly before valve gluing.
    Pump/flow meter fitting assembly added to input manifold pipe.
    Getting ready to glue the valves onto the two sides of the manifold.
    Adding water level set valves to each side of the input manifold.
    Two sides of the manifold assembled with valves.
    Both completed sections of the manifold placed on either side with the middle T-piece primed and ready for gluing.
    Manifold glued and installed, with the waste water draing valve to be glued in place next.
    Gluing the waste water drain valve and pipe
    Manifold completely Assembled and installed.
    Both manifolds in place, directly above where the reservoir will be placed, perfect.
    View from below after both manifolds and fence posts rows installed
    Everything in place after moving the rest of the junk out of the space.
    Netted pots in place
  • Water Circulation and Manifolds
    STEAL-THIS-HARDWARE09/13/2015 at 07:55 0 comments
    The NFT grow system is constructed from PVC fneceposts and PVC pipe. The fence posts hold the netted pots where the plants grow, the PVC pipe is used for piping the water in and out. For this system I build an input manifold from 3/4 inch PVC pipe and PVC ball valves. The purpose of the ball valves is to so the water level inside the fenceposts can be adjusted, when the plants are first starting out the water level has to be high, when their roots grow big enough the water level can be lowered. Eventually I intend to motorize these valves and add sensors to enable closed loop water level tuning. The next piece I worked on was the drainage manifold, it consists of 1 1/4 pipe and a few 1 1/4 inch fittings. The drain manifold is made from larger sized PVC so that the water drains fast enough relative to the circulation pump. In the picture below I show how the drain manifold will go together:
    Pipes, fittings, valves, etc
    As for attatching the manifolds to the fenceposts I originally was planing on drilling holes in the endcaps and using PVC glue and epoxy to hack it all together. I decieded that would be a rather terrible way to put it together so I did some research on what other folks are doing with similar builds and someone recommended uniseal gaskets. They work really well and they are very simple to install, basically you buy a seal based on the size of pipe and they have a hole-saw chart explaining what size hole is required for the seal, just drill the hole pop in the seal and push in the pipe, water proof and you can take it apart for cleaning. Here is where I got them BTW http://www.aussieglobe.com/uniseal1.htm
    The input manifold pictured not yet finished, next pipe needs to be cut to join the two sides with a t fitting in the middle that connects to the circulation pump in the reservoir. Also in the picture the two halves are different sized, I was still deciding on the exact spacing I wanted. I should also note that I primed and painted the wood frame to that nice planty looking green color, I think it turned out great and gives the rig a nice look, the plan is to build another rig but paint it a different color. Its really just for fun.
    In addtion to the manifolds I finally found a reservoir for the system. I was planning on a 55 gallon water barrel originally but that would be too much water and require a bigger more expensive pump, I also decided to build the green two by four stand shorter in case plants get way too tall. The next idea for a reservoir was a storage container, at first I was going to go with a 10 gallon container but ultimately decided to get a 16 Gallon container because the dimensions allowed for a better fit underneath the grow system itself. Inside the reservoir is s submersible pump used for circulating the water through the NFT system, connected directly to the input manifold. Also in the reservoir are aquarium airstones connected to an aquarium air pump , this serves to aerate the water/nutrient-solution and agitate it to prevent stagnation/algea growth.
    Submersible Pump, airstones, tubing, fittings, and leftover air valves.
    16 Gallon storage container, AKA the reservoir!
    Rervoir internal setup, 185GPH submersible pump and airstone setup.
    How all this works:
    The diagram above should explain the general idea behind everything discussed in this log update. The pump sits in the reservoir and pumps water into the fenceposts via the input manifold, the water drains after flowing from the fenceposts into the drain manifold and back into the reservoir. Stay tuned for more!
  • Materials and Construction
    STEAL-THIS-HARDWARE09/10/2015 at 02:23 0 comments
    Materials: 2X4s, 4X4s, and 5X5 PVC fence post
    Cutting Fence posts, I bought two 8 foot lengths and cut them in half for four 4 foot units. Each unit will hold 4 plants in 3" diameter hydroponic plastic grow baskets, filled with hydroton grow media.
    All Cut, the chop saw wasn't big enough to fit the whole width of the post so I had to rotate it 3 times to cut them, I don't recommend this but if you do wear safety glasses and be very careful.
    Measuring spacing of the plant pots and drilling pilot holes for the hole saw. I was planning on using my 3 inch hole saw to cut holes for the pots but the drill (on the table) I have won't fit the hole saw. I need to borrow a friends drill to finish. Next off for building the unit will be the frame, I haven't decided what the frame is going to look like. Simple requirements for it will be to mount the 4 rows and be tall enough to fit a 55 gallon water barrel underneath to act as the reservoir for the system. I plan on using the 4X4s to make legs and to build the rest of the frame with the 2X4s.
    So thats what I got done on the unit so far, I'm hoping to do some more work Friday if its nice outside to use the saw, stay tuned for more updates later!
    Last week I did a lot more work on the NFT grow unit the HydroPWNics control system will be deployed on. I finally decided on a simple design to hold up the 4 cut piece of fence posts holding the plants. I choose to cut the two by fours into two pieces one larger than they other. I used all these piece to make a simple box frame and added boards on top to strengthen and support it further. Its hard to describe with words so I have included a bunch of pictures of what I have done so far:
    Materials laid out being measured and cut
    Wood all cut to length, time to drill pilot holes and screw it all together:
    Just placing it together to see how it fits and see how well the cuts came out. The cuts were spot on, and everything slid together without any real big gaps between wood. You can see how the pieces were cut purposely uneven (like how I mentioned before) so that they fit together neatly at each corner.
    Closer look at the at the construction
    Its much darker out because it took me a while to find some clamps around the house. I clamped each joint together, when I drilled the pilot holes and left them clamped when I added the screws. It took much longer to clamp and drill pilot holes but in the end I didn't get any cracks in the wood and everything went together rather smoothly.
    Closer look at the clamp placement and placement of the wood. I forgot to take pictures earlier but what I did firs was take the longer lengths of two by four for the frame and bolted them to the top planks at the end, which are also the same length. I did that first to make it easier to clamp, drill, and screw each corner of the frame.
    The frame after the first day of work. The middle two by fours are screwed in from the top and side, so they are held in place rather well. One got attached crooked and it makes things look weird but I plan to fix it later before I paint the frame.
    Stay tuned for another update on the frame as well as the rest of the project either later tonight or tomorrow. This post is for last week's work and I just forgot to make a post. I hope to have some more to show from this past week, so stay tuned!!!
    Posts all drilled with pots in all but 4 positions, see that the frame isn't finished, more on that next!
    Today I finished the wooden frame of the whole unit. I added the crossboards and legs, take a look at the pictures to see what I mean:
    Dry fitting the legs after the cross boards added to the top of the frame.
    To attach the legs securely and straight, I clamped them tightly into each corner with the same two clamps I used the other day. I used a spare piece of the 4X4 wood to hammer each leg after being clamped to make sure its flat up against the board on the top of the frame. I used 4 screws on each leg. I'm trying to decide if I want to have crossmembers between the...
  • Comprehensive BOM
    STEAL-THIS-HARDWARE08/07/2015 at 04:23 0 comments
    Hey folks, this project log is just to show what the BOM looks like currentlt. This project isn't intented to be worked on to too much, it is essentially a sub-project to HydroPWNics anyways here is where the BOM stands at around $217 USD
    PartQuantityPriceSubtotalSupplierLinkNote
    5X5" Fence Post 10FT2$24.97$49.94Loweshttp://www.lowes.com/pd_17708-73428-73013947___?productId=4009495&pl=1&Ntt=5x5+fence+postInstore
    5X5" Fence Post Top8$3.27$26.16Loweshttp://www.lowes.com/pd_87410-73428-73013955___?productId=4062631&pl=1&Ntt=5x5+fence+postInstore
    2X4 Stud 92 5/8"4$2.56$10.24Loweshttp://www.lowes.com/pd_6003-99899-SG2408SPF_0__?productId=3604676&Ntt=Instore
    2X6 96in2$4.57$9.14Loweshttp://www.lowes.com/pd_432484-42597-WF206TOPCHC08___?productId=4082904&pl=1&Ntt=2x6x8Instore
    4X4 96in2$9.94$19.88Loweshttp://www.lowes.com/pd_4023-99899-528298_1z13cih__?productId=3606730&pl=1&Ntt=4x4Instore
    3/4-in x 5-ft 480-PSI Schedule 40 PVC Pipe3$2.49$7.47Loweshttp://www.lowes.com/pd_23972-1814-PVC+04007++1000___?productId=3133087&pl=1&Ntt=3%2F4+in+pipeInstore
    3/4-in Dia 90-Degree PVC Sch 40 Slip Elbow3$0.40$1.20Loweshttp://www.lowes.com/pd_23868-1815-406007RMC___?productId=1067627&pl=1&Ntt=3%2F4+in+fittingInstore
    3/4-in Dia PVC Sch 40 Tee4$0.46$1.84Loweshttp://www.lowes.com/pd_23874-1815-401007RMC___?productId=1067661&pl=1&Ntt=3%2F4+in+fittingInstore
    3/4-in Uniseal Gasket4$1.30$5.20AussieGlobalhttp://www.aussieglobe.com/34-Uniseal--U075_p_10.htmlShipping Cost depends on location
    1 1/4-in Uniseal Gasket4$1.89$7.56AussieGlobalhttp://www.aussieglobe.com/1-14-Uniseal--U125_p_12.htmlShipping Cost depends on location
    3/4-in to 1/2 female thread PVC fitting1$0.56$0.56Loweshttp://www.lowes.com/pd_23862-1815-435007RMC___?productId=3339820&pl=1&Ntt=3%2F4+pvc+fittingInstore
    3/4-in pvc ball valve4$1.21$9.84Ebayhttp://www.ebay.com/itm/221574678613?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT5 Dollar Shipping included in price
    Submersible Pump1$16.45$16.45Amazonhttp://www.amazon.com/EcoPlus-185-Submersible-Pump-158/dp/B0018WVNXC/ref=sr_1_1?ie=UTF8&qid=1438882068&sr=8-1&keywords=185GPH+pumpShipping Cost depends on location
    3" Netted Pot50-------$15.45Ebayhttp://www.ebay.com/itm/161092202131?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITFree Shipping
    Reservoir, 17 gallon storage container1$10.88$10.88Walmarthttp://www.walmart.com/ip/Sterilite-16-Gallon-Storage-Trunk/24673334Instore Only
    1-1/4-in Dia 90-Degree PVC Sch 40 Slip Elbow2$1.26$2.52Loweshttp://www.lowes.com/pd_23872-1815-406012RMC___?productId=3307888&pl=1&Ntt=1+1%2F4+pvcInstore
    1-1/4-in x 5-ft 370-PSI Schedule 40 PVC Pipe2$4.62$9.24Loweshttp://www.lowes.com/pd_23982-1814-PVC+07100++1000___?productId=3133099&pl=1&Ntt=1+1%2F4+pvcInstore
    Aquarium Tubing Connectors-$4.56$4.56Amazonhttp://www.amazon.com/gp/product/B0051SM6GW?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s00Shipping Cost depends on location
    25 ft Aquarium Tubing1$4.56$4.56Amazonhttp://www.amazon.com/gp/product/B0002563MW?psc=1&redirect=true&ref_=oh_aui_detailpage_o07_s00Shipping Cost depends on location
    10PCS 1-inch Mineral Bubble Release Aquarium Air Stone Airston10------$4.50Amazonhttp://www.amazon.com/gp/product/B00CQGXBJ8?psc=1&redirect=true&ref_=oh_aui_detailpage_o08_s00Shipping Cost depends on location
    Tetra Whisper Air Pump (Non-UL)1$8.49$8.49Amazonhttp://www.amazon.com/Tetra-77851-Whisper-Pump-10-Gallon/dp/B0009YJ4N6/ref=sr_1_1?ie=UTF8&qid=1438921090&sr=8-1&keywords=aquarium+pumpShipping Cost depends on location
    $217.19Total
View all 5 project logs
  • 1
    Step 1
    Fence Rows
  • 2
    Step 2
    Frame
  • 3
    Step 3
    Input Water Manifold
View all 4 instructions
Darko Shapiro wrote 02/21/2024 at 20:16 point
Interesting project.
I actualy have some problem with my lavender leaves drooping. Do you think that this can be the solution?
Thanks for your answer
Sjoerd W wrote 08/07/2018 at 13:18 point
Hi Adam.
5/8" (16 mm) is available (and the smallest size for PVC tubes I could find), but it is only approx 3 mm smaller in diameter then 3/4", so I think using a bigger pump is the best option. I came across a project (https://www.instructables.com/id/Arduino-Controlled-Smart-Hydroponic-Modular-System/) which uses a 1000L/H pump for 40 mm (1 9/16") PVC tubes. BTW what do you think of that project? I did ask them if it was a NFT system, but no answer yet. If one (I?) could combine your and their project, that would seem ideal!
STEAL-THIS-HARDWARE wrote 08/07/2018 at 13:48 point
Their system appears to be NFT too, they are just using PVC pipe instead of fence post for the grow units. NFT is characterized by a shallow water level filled with nutrients hence it being described as a film etc. Yeah I understand if you cant fine thinner pipe but  bigger pum will help with that. Another route you could go is to use rubber tubing and fittings to join them together instead of PVC pipe, its totally valid and I have seen people build NFT systems using rubber tuning instead of pipe a lot. Hope this helps, your inquiries have got me interested in my own project again, I might have to set one of these up in the winter.
Sjoerd W wrote 08/08/2018 at 15:47 point
I think I can deal with the size issue of the various components, but I still don't understand how NFT works. To me it seems necessary to lower the height of the water level proportional to the length grow of the roots of the plant. So you start with a rather high level of water when the plants are still young and their roots are small and then lower the level (gradually?) when the roots grow in length. This seems to me the idea of NFT. If this is right how do you accomplish this in your system?
STEAL-THIS-HARDWARE wrote 08/08/2018 at 17:17 point
The depth of water in the pipe is controlled by the drain pipe piece. I cut 3, 4, 5 inch drain pipes for each row. You are essentially controlling water depth by raising the drain hole with the short length of pipe. Another route is to prepare the plans in a cloner unit, I grew all my plans to the the point that they had very long roots and I just installed them into the NFT unit I built. And yeah you have the concept right, you want the roots to be really long and for their to be minimal water in the bottom.
Sjoerd W wrote 08/09/2018 at 12:08 point
I understand your solution for managing the water level, quite logical actually. Raising the plants could also be an option, but a good start would be indeed using pre-grown plants having already good long roots.
I'm still gathering idea's from the many, many internet/YT sources and hope to come up finally with a solution that fits my situation best.
Sjoerd W wrote 08/05/2018 at 13:04 point
Hi Adam, very well explained and illustrated project! I'm interesting in building this. I did check out the availibily of the various components in The Netherlands and seem to find most of them (or a suitable replacement), be it a bit more expensive then in the USA. Just a minor detail: in your component list you mention 1 x pvc ball valve 3/4", but this should be 5, isn't it?
I assume you did build this system and started to grow some veggies ;-). Did you encounter any problems?
STEAL-THIS-HARDWARE wrote 08/05/2018 at 21:10 point
Yeah you need one ball valve per row of plants. Also if you can go smaller than 3/4" for the input manifold it will work much better. The 3/4" diameter didn't give me the water pressure that I wanted, I had to buy a larger pump to up the pressure. Other than that it worked really well. invest in a high end CO2 bulb grow light and this system will serve you well.
Sjoerd W wrote 08/06/2018 at 11:47 point
Thanks for the quick reply and the tip about the size of the manifolds. I'm planning to use this in a small greenhouse I will set up on my roof terrace. It can accommodate a size of about 15' x 10', and will make use of the sun and daylight. So I think probably no need for grow lights and CO2 enrichment.
STEAL-THIS-HARDWARE wrote 08/06/2018 at 17:19 point
That sounds like a good idea, you most certainly can use these setups outside, just paint the wood frame with some weather proof paint, plastic pipe should be fine and submergable pump is already water proof. The manifold issue was the only thing I'd change. Good luck and please post back here anythign you might make!!
