Bike Powermeter
A 2-part bicycle powermeter. Swap between bikes without tools in 5 seconds.
I have too many bikes at home. A road bike for racing, one for training, one for winter, a cyclocross bike and a MTB. Training with a powermeter is really cool, but buying powermeters for all my bikes is far beyond my budget. Of course there are powermeters which can be switched between bikes in several minutes, but e.g. pedal based systems for road bikes are not a good idea on a MTB.
Thus, I designed my own 2-part crank-based powermeter. The idea is to put parts on the crank arm which need to stick to the crank arm only. All other electronics are detachable and can be swiched between bikes in a few seconds. Really easy and fast.
The parts which are glued to the crank permanently are very cheap. Thus, fitting the measuring unit to all your bikes is also cheap. Only one single powermeter unit which is more expensive and carries all the electronics for analysing data and sending it via ANT+ to your bike computer is needed.
The pictures show the powermeter unit (powermeter as well as measuring unit permanently glued to crank). The measuring unit in the pictures is fixed with a rubber band, this will be omitted in future designs. The pictures also show the charging unit, a debug unit which can be attached between measuring unit and powermeter unit (for firmware updates and sniffing data) as well as a tool for calibrating the measuring unit with known weights.
Currently, calibration and comparison with my Elite Kura smart trainer as well as Garmin Vector 2s is ongoing. Comparison charts and further details coming soon.
  • 1 × Atmega 328p CPU
  • 1 × MPU6050 Gyroscope for cadence. Using DMP currently which consumes a lot of power.
  • 1 × nRF24AP2 ANT+ communication
  • 1 × M24C64 EEPROM for storing e.g. calibration data in crank-part of power meter.
  • 1 × HX711 ADC for strain gages. This one is really low-cost. We will see how it does its job when e.g. temperature changes.
  • In-saddle versus out-of-saddle
    rock-o-mat03/27/2018 at 01:03 0 comments
    I am still testing against my Elite Kura and Garmin Vector 2s. I calibrated the scale with only one known weight and assumed a linear relationship between torque and weight. It is close, but not close enough. There is a significant deviation between riding standing or sitting at the same power.
    The plot below shows the torque profile for one crank revolution. Standing and sitting cadence and power output was identical (as measured with Elite Kura and Garmin Vector 2s). However, my power meter measured 230W for sitting and only 220W when standing.
    The integrals for red and blue curves should have been equal, but they are not. The in saddle position gives a more smooth torque profile with a peak around sample 25. The out of saddle position peaks at sample 35 and differs in shape. The blue curves are only slightly higher than the red ones, in order to give the same power reading they should have been giving higher amplitudes at the peak. I assume that for higher torques the crank bends less and less.
    So, we have some nonlinearity here. I already included a second order term in my torque calculation which takes care of this.
  • First test ride (indoor)
    rock-o-mat03/21/2018 at 09:14 0 comments
    First test ride is done. Ok, this one was easy, indoors on smart trainer, no changing weather conditions. I compared the output of my DIY power meter with the outputs of my Elite Kura smart trainer (claimed to be 1% accurate) as well as Garmin Vector 2s.
    I am quite confident that I am on the right track. This plot shows the raw ANT+ data, no smoothing applied:
    Even short "sprints" are managed quite well:
    But will this work outdoors? Currently, we have like -3° C outdoors, so it will be a difference of 25° C between the warm crank at start and freezed crank at the end of the ride. We will see...
View all 2 project logs
bearmos wrote 03/22/2018 at 12:00 point
also, check out the molex MX120G series headers for an inexpensive IP67 rectangular connector (they're probably too big). They would provide a nice robust watertight connection (a concern once you get this out into the weather).
https://www.digikey.com/product-detail/en/molex-llc/0367831201/WM9330-ND/3661543
https://www.digikey.com/product-detail/en/molex-llc/0367921201/WM9332-ND/3661542
You could also design in an o-ring gland, but that's probably a bit more challenging than spec'ing a water tight connector, since it would have to be kept sealed.
rock-o-mat wrote 03/22/2018 at 17:06 point
Yes, this is too big. The thickest part of my power meter is 12mm, the current 2 row connector is only 5mm. I think that I can drop the debug pins in future designs making it a 1 row connector, but still it needs to be really thin. There is not much space between crank and frame.
bearmos wrote 03/22/2018 at 11:48 point
Looks really promising!  If you run into issues with temperature drift from the HX711, you could try an LMP90100 (gain stability is 0.5 ppm/degC) which is an order of magnitude more stable than the HX711, and the raw IC is also able to be sourced directly (I can only find the HX711 from sparkfun)
rock-o-mat wrote 03/22/2018 at 17:15 point
Temperature drift might be an issue on HX711. But it is cheap and easy to get here in europe. Thus, I will try to deal with temperature variations in software. If this is not going to work, I will switch to a different ADC. So thank you for pointing me to the LMP90100.
