Documentation is not my strong suit...
05/04/2019 at 04:42 • 0 commentsThis project is the kingpin of several projects I've done, that 'just worked'. Well, this part worked anyway...
I built what I've used here 95% based on someone else's code, with very minor modifications, and it has done everything I've ever set out to do with it.
As such, it has seen use for pretty much everything I have ever needed in this realm, and I've never gotten back around to documenting it!
Where the artistic side emerges, the technology which enabled that art fades away. As it should...
Or.... My code actually sucks and I'm embarrassed to release it. One of the two. :)
You will see this, and what I've done with it, next Christmas (assuming I'm in Florida for it anyway).
I have plans...
MasterOfNull
