This workshop ran at the Hackaday SuperConference 2015.
You can check out the slides in the GitHub repository here: https://github.com/sparkfun/crowdsourcing_control_esp8266_thing.
If you have any questions, you can open issues on the GitHub repository or on here.
Toni Klopfenstein
Hi @Toni Klopfenstein, and anyone else who wants to chime in, l was doing a bit of reading about programming this Thing. When I could not get GNU Screen to work I tried Arduino's Serial screen. I got gibberish. After more investigating I read about cutting the trace on the bottom side of the Thing. Then soldering on a header with two pins. When I want to upload a sketch to the Thing I'm to add a jumper (pin connector) to the pins. Does this sound like a wise thing for me to do to my Thing? Or, should I leave it alone and monkey with the ones I bought from the Hackaday store? They are Hackaday ESP8266s made by Adafruit. The bottoms are black with Hackaday Logo on them. I couldn't resist. ( R1=0 ohms)
Greg
