BEEP communicator
Because all robots should beep
This module is being created to produce robotic beeps and tones, and to also decode the tones back into meaningful data. This will allow communication between small robots using low bandwidth beeps. Hardware will consist of a small speaker, a microphone and an STM32 ARM processor.
I want to use one of the ST dev boards to prototype this project. Having support for mBed, Arduino and GCC without having to purchase any programming tools makes the NUCLEO boards a no brainer for me.
The F303K8 is the smallest form factor board that supports DSP, so I'll plan to use it for now. The rest of the circuit is fairly straight forward. It basically consists of a way to get audio in and out of the microcontroller. An electret condenser mic with some buffering will feed the ADC input. On the output I'll plan to either bit-bang or PWM the speaker through a small N-channel FET. The circuit may (and probably will) evolve from this basic schematic, but it's a starting point and enough to start looking for parts.
ShopCart.csv
Element14 shopping cart for prototype parts
Comma-Separated Values - 2.53 kB - 03/16/2018 at 23:21
Download
  • 1 × NUCLEO-F303K8 ST development board
  • 1 × ABM-707-RC Pro Signal Microphone
  • 1 × KSSG2308 Kingstate Speaker
  • 1 × BC847C Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 1 × RC0805FR-0710KL Resistors (Fixed) / Thick Film Surface Mount
View all 9 components
  • Testing tones
    MattF • 03/18/2018 at 01:15 • 0 comments
    Before I start coding I'll need to come up with some audio samples so I can create a set of tones to use as data symbols. I'd like to make it sound robotic and synthesizer tools are a good way to test what works.
    I've been looking at https://onlinesequencer.net/ (no affiliation) mainly because it's online and I can save the output.
    So far I've recognised that high-ish frequencies sounds good, and that using a musical key makes any combinations sound too... musical.
    Example audio so far http://onlinesequencer.net/763546
  • First parts order
    MattF • 03/16/2018 at 23:27 • 0 comments
    Parts to build two prototypes have been ordered. I've added the parts I chose to the project component list, I also uploaded a copy of the shopping cart in case anyone wants to see exactly what I order/cost etc.
    Once the parts arrive the the first step will be to get the dev boards running, then build the hardware and start generating some tones. In the meantime I can start generating some tones on my PC to see what frequencies/combinations I might want to implement. If anyone has any ideas, please let me know!
    Please hit like if you're interested in the project. Now that I've actually put money into this, it will really help me out.
View all 2 project logs
PixJuan wrote 05/11/2018 at 20:21 • point
Nice idea!
I was mentoring students for the https://hackaday.io/project/12225-bicycle-gps project and they used a very simple way to spot some frequencies with pulseIn https://www.arduino.cc/en/Reference.PulseIn
I don't know if mbed has similar functions.
