MultiSupply: For my Little ElexLab
Simple LM317 based Power Supply with: +12V, +9V, +5V, +3.3V DC output
Just a stupid idea. But Very handy for small testing and sort-of works. Simple Power supply : - Low Cost. - Easy to Build. - Easy to Use. - Easy to Troubleshoot.
My little lab needed little power supply. For testing and simple powering purpose. Main goal here is
  • Should be extremely low cost.
  • Should be Single layer, for DIY PCB Etchers.
  • Should use components, which are easily available.
  • Should be,
    • Easy-to-Assemble
    • Easy-to-Test
    • Easy-To-Troubleshoot.
Circuit designed around:
  • LM317 Adjustable regulator. With Heat-sinks.
  • DC Socket at Input.
  • Low cost SMD 1206 Rs & Cs.
  • LED for POWER Indication.
  • Terminal Blocks for each Output.
  • Bonus USB-A-Female Connector [+5V],
Design Files are licensed under the CERN OHL v. 1.2.
You may redistribute and modify this documentation under the terms of the
CERN OHL v.1.2. (http://ohwr.org/cernohl). This documentation is distributed
WITHOUT ANY EXPRESS OR IMPLIED WARRANTY, INCLUDING OF
MERCHANTABILITY, SATISFACTORY QUALITY AND FITNESS FOR A
PARTICULA.
DipTrace PCB - MultiSupply_bot.pdf
Adobe Portable Document Format - 19.75 kB - 03/20/2016 at 20:14
Preview
DipTrace PCB - MultiSupply_top.pdf
Adobe Portable Document Format - 18.42 kB - 03/20/2016 at 20:14
Preview
multisupply BOM.csv
ms-excel - 433.00 bytes - 03/20/2016 at 20:09
Download
  • 1 × LM317 Power Management ICs / Linear Voltage Regulators and LDOs
  • 1 × Resistors SMD 1206
  • 1 × Capacitors SMD 1206
  • 1 × Electrolytic Capacitors
  • 1 × USB Connector
View all 8 components
  • PCB Design
    Amar Potdar • 03/20/2016 at 20:30 • 0 comments
    Well, As stated earlier, My goal is to design board such a that any DIY PCB etcher can do.
    So, I gave special preference to net classes, by making all of them to 1 mm. [thicker traces are best in Iron based toner-transfer method]
    I choose DipTrace PCB tool to design the board, It's really an easy tool to work with.
    Speaking of placement, I followed K.I.S.S.[Keep it Smart & Simple] rule, and tried well for it.
    Placement:
    Routing:
  • Circuit Design
    Amar Potdar • 03/20/2016 at 20:20 • 0 comments
    LM317 being widely used regulator. It's circuit is straight forward and proven. It didn't take much time to put all the pieces together. And within no time I was ready with Schema.
    5mm LEDs at the output end of each LM317, to indicate the ON/working status.
View all 2 project logs
