Graphs
Using pygame for visualization on the PC. Teensy sends the measurement data through serial and PC does live graphing. The data is also saved in a text file.
Planning adding an amplifier/attenuator with volume knob. Something to boost the teensy output to a much higher level.
marcell marosvolgyi
PCB designer
Bruce Land
