Gator
An attempt at building a small CPU following software development methods
nsnNsN
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Gator is a small CPU build using only the basic blocks of transistors, resistors and capacitors. It is also a project to test on how to apply some methods from the realm of software development to the task of hardware development. The main concepts explored at the moment are modularity and test-driven design.
