Foam Cutting Tool Specs:
* Prototype cutting Width: 3" Wide X 3.5" Deep
* Prototype cutting Wire: Kanthal (same wire used in vapes)
* Time to Fully Charge @ 5V 2A: 2 hours | @ 5V 1A: 3 hours | @5V 500mA: 4.5 hours
* Capacity: 3350mAh/3.6V * Type: Panasonic NCR18650B Lithium-Ion
* Size: Diameter: 1.6 inches * Length: 8.1 inches
* Body Material: Nylon * Weight: 101g (3.5 oz)
* Input Cable - 3' Nylon Braided Male USB Type A to Micro Connector
* Input - Current: 450 to 1300mA | Voltage: 5 to 6 Volts
* Output - Current: 1500mA | Voltage: 2.5 to 4.2 Volts
* Battery Life Under Typical Use: Over 5 years * Replaceable battery
* Provides over 2 hours of working time
Solarcycle
Beast Devices
bornach
Meta Unknown
Discreet Mayor
