The Mini Quadruped Mobile Robot
mePed is an awesome little open source quadruped robot which allows anyone to build their very own walking robot.
octect-stream - 664.38 kB - 09/21/2016 at 23:05
x-zip-compressed - 40.49 kB - 09/21/2016 at 22:59
ino - 16.19 kB - 09/21/2016 at 22:46
x-zip-compressed - 118.43 kB - 09/21/2016 at 22:45
AutoCAD DXF - 740.58 kB - 09/21/2016 at 22:45
View all 8 components
Do you have any videos of it walking?
Here's the video we did for our Kickstarter campaign: I'll try to shoot some more videos of it walking and an assembly guide soon. Thanks!
Hi Radomir,
Thanks for the suggestions, I'll have to look into the SG92R Servos! I hadn't given much thought to 3DOF Legs simply because I wanted to keep the servo count to a minimum to make it more affordable and reduce the buyout part count.
Hi, you might be interested in some of my experiments with #Tote.
From what I see in the pictures, I have some suggestions/questions:
* Try SG92R servos instead of MG90S. They are lighter, cheaper and stronger. They use carbon fiber gears instead of metal gears.
* Consider using plastic (acrylic or nylon) bolts to reduce the weight.
* Have you thought about going full 3dof?
Doan Hong Trung
Nguyễn Phương Duy
Campbell Flagg
Roger Cobra
Yes, delete it Cancel
You are about to report the project "mePed", please tell us the reason.
