Repairing an Anker E5 16000mAh Powerbank
Back to overview
How to replace the USB connectors and/or ferrite bead on your Anker pack.
mark999 wrote 07/11/2023 at 05:10 point
Be careful opening one of these. I had a puff of magic smoke; the PCB and cells were attached to opposite halves, and pulling the two apart caused the positive end's metal strip to cut through the insulation on the negative lead. It doesn't seem that any harm was done to the cells, as the negative lead's tab acted as a fuse. Still alarming though!
Rado wrote 10/21/2019 at 23:08 point
Hello !
What type of batteries did you find?
Lithium or cadmium ?
Thank you
Rado M
Jason Chow wrote 06/07/2022 at 12:58 point
They are lithium cells - LG LGABE11865
http://keeppower.com.ua/download/lg18650e1.pdf
https://secondlifestorage.com/index.php?threads/lg-lgabe11865-cell-specifications.1750/
