Layout features include:
-F13 through F24
-Media keys
-Macro Keys
Produced with:
-Kailh BOX Navy switches
-DSA Keycaps with Dye Sublimation Legends
-Cherry Stabilizers
A custom 136 key mechanical keyboard, inspired by the Sun Type 5 keyboard, and the classic phone dial-pad.
-F13 through F24
-Media keys
-Macro Keys
Produced with:
-Cherry Stabilizers
Plate&CaseBuilderSettings2.JPGsettings specified in screenshot: cut polygon:circle:Top&Switch layer only 6mm diameter relative to [0,0] [x-72,-y+15];[x-53,-y+15];[x-34,-y+15];[x-15,-y+15] cut polygon:circle:all layers 3mm diameter relative to [0,0] [-x+15,-y-1.5]; [x-15,-y-1.5]; [-x+15,y+1.5]; [x-15,y+1.5];[0,y+1.5];[0,-y-1.5] add polygon:custom poly:all layers relative to [-x,-y]; [x-30,-y]; [x-30,y]; [-x,y];[-15,y];[-15,-y] clockwise points [0,0]; [5,-5]; [25,-5]; [30,0]; [25,5]; [5,5]JPEG Image - 90.22 kB - 06/18/2018 at 01:33 |
Plate&CaseBuilderSettings1.JPGsettings specified in screenshot: case type: sandwich usb cutout at -120 edge padding 5mm cherry only stabilizer switch type: mx _t:3JPEG Image - 54.85 kB - 06/18/2018 at 01:33 |
Plate&CaseBuilderSettings3.JPGsettings specified in screenshot: Line Weight: 0.01mmJPEG Image - 24.83 kB - 06/18/2018 at 01:33 |
Sundial_KLE(AsUsedForPlateBuilderApp).txtThis was the KLE text used for the plate builder.plain - 7.01 kB - 06/18/2018 at 01:26 |
CNC_CUTOUTS_ALL_LAYERS.zipOutput from the keyboard plate builder tool at http://builder.swillkb.com/ (Used raw KLE from http://www.keyboard-layout-editor.com/#/gists/2771f208f8110f4429eae55af6480313 as input. )x-zip-compressed - 123.69 kB - 06/18/2018 at 01:19 |
its always good to see a bigger keyboard
