Portal Point Generator
An efficient and compact generator that can be coupled with wind turbines or water wheels to produce upwards of 100W
Public Chat
Originally designed and built to take on an expedition to Antarctica coupled with a wind turbine. Portal Point was one of the locations in Antarctica that this was set up to generate power to charge electronics, and hence named after it.
I was unable to find a cost-effective generator and using motors backward to generate power seemed too wasteful because of their inherent detent torque. I decided to go back to fundamentals and build a turbine would give the maximum possible output for its size.
This generator was used in Antarctica along with CFA2018 and the organization 2041 to generate power and power our electronics. It goes to show the resilience in 3D printed parts and what amazing things this technology can do in the future and play an important role in creating a sustainable future.
What is a Dual Axial Flux Generator?
A dual axial flux generator consists of powerful magnets placed on either side of a fixed stator winding, like a sandwich creating a very strong magnetic flux between them, and thus inducing a powerful EMF in the stator winding when in motion. Since the magnetic flux is axial to the output shaft, it is an axial flux generator, unlike a radial flux generator like that most commonly found in DC motors that are converted as dynamos.
I chose to build this kind of generator, since it creates a dense magnetic field and makes the most efficient use of the magnets. There is hardly any magnetic flux leakage outside the generator itself.
Another upside is that, it makes the generator flat, and is easy to construct, as well as integrate into power generation projects.
The the expedition to Antarctica,  I coupled this along with a Helical Wind Turbine Design (https://www.thingiverse.com/thing:99132) to create a Wind Turbine we could use to charge our electronics and equipment with.  In this documentation I shall also outline coupling the generator to the wind turbine project as well.
Standard Tesselated Geometry - 444.61 kB - 07/13/2018 at 10:47
Download
Standard Tesselated Geometry - 259.16 kB - 07/13/2018 at 10:47
Download
Standard Tesselated Geometry - 80.94 kB - 07/13/2018 at 10:47
Download
Standard Tesselated Geometry - 60.82 kB - 07/13/2018 at 10:47
Download
Standard Tesselated Geometry - 42.95 kB - 07/13/2018 at 10:47
Download
View all 15 files
  • 16 × N52 Neodynium Magnets 40x20x5mm
  • 1 × 30 AWG Enamel insulated Copper Wire (M)
  • 250 × M4 Threaded Road (mm)
  • 1 × 1.2mm Mild Steel Sheet 200x400mm
  • 1 × 25A 50V Bridge Rectifier
View all 8 components
  • Rotors
    Vijay4 hours ago 0 comments
    The picture below shows of the rotor stacks up into an assembly. The magnets get embedded into the magnet housing, and is covered by a laser cut sheet metal cover. The sheet metal cover prevents magnetic flux of the powerful magnets from going out of the generator, and also makes the flux stronger on one side of the Magnets.
    The rotor brace prevents the powerful magnets from collapsing into each other ( THE MAGNETS ARE FREGGIN POWERFUL), as well as provides a way to mount the drive shaft. Use M3x16 CSK screws to mount everything together.
  • Star Topology Arrangement​
    Connect the phases in a delta pattern. There are 2 Coils for each phase. The coil on the opposite sides are of a single phase.
    Connection coils of the same phase in series first, the "OUT" of the first coil with the "IN" of the second coil of the same phase.
    The above picture shows 9 coils, but its connected the similar way for 6 coils as well
    Then connect all the remaining "IN"s of the three phases together which would be the common ground. All the "OUT"s will be the three phase output.
    In the below images, I covered the coils with the stater cover, and marked the IN's and OUT's of the coils to aid wiring.
    Figure 24: Twisting joints of wire pairings (as per description)
    removed the enamel from the ends of the wires with sand paper:
    Figure 21: Stripping enamel off the copper wire with the help of sand paper
    (My desk is messy, i know)
    here im' soldering two coils of the same phase together.
    Figure 23: Soldering pairings of copper wires
  • Stator Assembly
    Vijaya day ago 0 comments
    Coil Placement:
    Place the coils inside the Coil Holder/ Stator. There are three pins inside which the coils will sit.
    The "IN" and "OUT" of the coils where the winding started and ended need to the placed in the appropriate notches. These will help identify how the coils would be wound.
    Figure 15: Coils placed in coil housing
    Coil Housing Preparation:
    Glue gun the coils in place.
    Figure 16: Glue applied to raised edges of the coil housingApply glue to the edges of the coil housingFigure 18: Coil housing being coveredThe coil housing is covered with the 3DP Housing CoverFigure 19: Coil housing being covered
  • Assembly Process: Jig Preparation + Coiling
    Vijay2 days ago 0 comments
    Jig Preparation:
    The winding jig is used to wind the coil. The Jig and the Jig holder are fastened together using M3 fasteners.
    Figure 1: Both jigs affixed together along their shape and their elevations facing each otherPrint 2 Jigs,  fix them along their shape, and elevations facing each other.
    Figure 2: Jig handle attached to the jigs on one faceAttach the 3DP Jig Holder on one of the faces. I recommend marking this face, and you should use the same convention when winding all the coils., and the winding direction should match.
    Figure 3: Jig handle attached to the jigs on one faceFasten everything togehter
    Figure 4: Wire inserted through hole in the jig to help the wire sit in the grooveThere is a small hole in the jig through which you can slot the wire, to keep it in place while winding.  Put the 30 AWG wire into this from the inside of the jig, coming out.
    Figure 5: Attach kapton tape to the face of each edge in a reverse manner to help get the coil out of the grooveAttach kapton tape in the 3 slots . Once the coiling is done, the kapton will be folded onto the finished coil to hold its shape.
    Coil Preparation:
    The jig is mounted on a power screw driver/drilling machine using a HEX bit. There is a notch on the jig to indicate when the maximum number of coils are reached.
    Try and maintain a constant level of tension on the coils to get a roughly same number of coils. 6 coils will need to me made like this.
    Use kapton tape to keep the cool from unwinding. Keep the kapton in place on the inside of the coil, and wind on top of it.
    There is a hole on the jig where the start of the coil is placed. As long as you use the same convention for winding, and placing into the coil holder, you should be alright, only the polarity of the DC would change.
    To Do: Automate this process with a encoder and counter to be more accurate.
    Figure 7: Wire being wound around the jig with the help of a hand drill and drill bit
     If you have the patience, you can hold the handle and wind by hand, or use a drill/power driver to make this faster. You need 6 coils.
    Figure 8: Unscrewing the jig handle
    Fold the Kapton tape over the coil to hold it in place. Now work backwards to remove the coil.
    Figure 9: Removing the jig handle
  • Story
    Mission:
    To make energy generation accessible with 3D printing.
    Story:
    I had been selected to join the International Antarctic Expedition (IAE), ClimateForce: Antarctica, that equips leaders with resources and actionable solutions to become a part of a global force of change.
    This expedition gave me the ability to learn from experts on the subject of climate change as well as equip myself to be in a position to create an impact back home.
    I wanted to use this opportunity as a platform to promote the use of 3D printing to give access to renewable energy to as many people as possible. Even though the maximum output if this generator is 50-100W, it can act as a blueprint for others to get into improving manufacturability of wind turbine or generator designs. Maybe this could inspire some college students who take up this project to pursue renewables as a career.
    This generator was used in Antarctica along with CFA2018 and the organisation 2041 to generate power and power our electronics. It goes to show the resilience in 3D printed parts and what amazing things this technology can do in the future and play and important role in creating a sustainable future.
                               Assembling the wind turbine in Antarctica proved to be quite a challenge with gloves on.
View all 5 project logs
Tinkerloonllc wrote 3 hours ago point
I love this!
Vijay wrote 4 hours ago point
Thanks Mike! :D
Carlos wrote 4 days ago point
Amazing. I can definitely use this on disaster relief deployments.
I hope it comes of use to you!
Dennis wrote 4 days ago point
You had better weather in Portal Point than I did!
earl wrote 4 days ago point
Are you going to make the plans available for others to print?
Vijay wrote 2 days ago point
They are up now,  will update process and procedure by today.
Aayush Khanna wrote 4 days ago point
Pretty cool stuff !
Thankyou!
Shah Selbe wrote 4 days ago point
Awesome project! I can see us using this in the field.
Thankyou! I hope the design comes of use to you!
Mike Szczys wrote 6 days ago point
A very cool build, and amazing that you tested it out in Antarctica, wow!
