Choise the PSU
I use OLD COMPUTER PSU about 300w from china. I cut all the wire not necessary.
Take the Necessary Component
The first i use iron solder for take 2 big heatsink. We only use the heatsink, all transistor and mosfet we don't use after that, I take 2 capacitor 330uF/200v, capacitor 105
The Transformer and Inductor
We have the transformer, inductor 2 big capacitor 330uF/200v,2 heatsink,2 resistor 330K , 1 fuse 5A/250V, 1 NTC MF725D9. The tranformer don't have the CT pin. The inductor have 6 pin. 2 pin of small wire we don't use.
Buy More Component
We need to buy some component.
2 capacitor 1uF/275v.
1 Line Filter Transformer.
1 Bridge diode KBL610.
1 Capacitor 220uF/16V
1 Capacitor 1uF/50V
1 Diode UF4007
1 Resistor 47K/5W
1 Resistor 10K
2 Resistor 22 ohm
1 capacitor 1n (102)
2 Mosfet irf730 ( irf740,irf840..)
1 Double diode 20100CT
1 Capacitor 100n (104)
1 resistor 10K
1 led 5mm
1 capacitor 1000uF/50V
1 socket 8 pin
1 IC IR2153
For more detail: Please copy the name of component and paste to google image search
The Schematic and PCB
The Schematic i design by Eagle Software and make PCB use Sprintlayout software. I hava attach the PDF file for you make it by yourself at home. If you want the good PCB you can upload gerber file tohttps://jlcpcb.com/m, i alway make PCB online from https://jlcpcb.com/mThey cheap and good quality. You can download all of them below Gerber file, Schematic and PCB at PDF file
https://drive.google.com/file/d/1wT_dql6bW_GdBXzPENKiXInLvPPmjw78/view
Solder the Component, SomeThing About 750W 24V DC Motor Speed Controler
At the top of PCB we have the name of component, you just put exacly component and solder. 750W 24V DC motor speed controler i have show you in previous project, you can check again for more detail
Firts Test 24V 15 Power Supply
For the first test. We must to connect with 220V/100W light bulb. If your project failure the light will on and you be safety.
Connect 24V/15A DC Power Supply and 24V 750W DC Motor Speed Control
Connect 24V/15A DC power supply and 24V 750W DC motor speed control. Thank for watching. If you have any problem please contact me, i will help you
