Automated mouse homecage two-bottle choice test v2
Version 2: A homecage-fitted apparatus for automated, photobeam-based detection of licks in a two-bottle choice task.
Public Chat
This is an update to the original automated mouse two bottle test.  It performs the same function as the last version but it has been revamped to make it battery powered and include a screen to display data.  It lasts about 2 weeks on the battery, making it a truly mobile drinking monitor!
This design fits into our colony caging (Allentown NextGen) while on the rack, for different caging you may have to modify the 3D design.
SipCounter-100618stable.zip
Sip counter code with outputs activated
Zip Archive - 10.09 kB - 10/06/2018 at 16:29
Download
Sipper BOM.csv
Bill of materials for the sipper device
Comma-Separated Values - 1022.00 bytes - 08/11/2018 at 21:37
Download
SipCounter-SetClock.ino
Arduino script for setting the time on the RTC
ino - 5.58 kB - 08/11/2018 at 19:34
Download
Sippers 080618.stl
3D design for the main piece
Standard Tesselated Geometry - 288.27 kB - 08/11/2018 at 19:02
Download
Sippers cover 080618.stl
3D design for the cover piece
Standard Tesselated Geometry - 20.39 kB - 08/11/2018 at 19:02
Download
View all 14 components
  • Editable 3D design
    Lex Kravitz03/06/2019 at 16:04 0 comments
    The 3D design was developed in TinkerCAD and an editable design is available here:
    https://www.tinkercad.com/things/gPan0GUSNkd
    Please don't judge us! This device went though a very iterative design process so the current design build is a bit complicated.  We'll hopefully re-design this more simply and update in the future (or if someone does this please let us know so we can post better design files!).
  • Troubleshooting
    Lex Kravitz02/04/2019 at 17:03 0 comments
    This log is about troubleshooting.  I'll add to it as we identify troubleshooting issues.  Please leave a comment if you know of any others!
    1) Sipper position
    While the electronics on the sipper device are pretty much bulletproof, we have noticed the position of the sipper tubes can shift a bit, so these should be checked carefully.  Specifically, it's possible for one tube to move out of the detection beam, which obviously introduces error into the experiment.  Here's an example, with the red line estimating the position of the detection beam.  The sipper on the right is positioned too far from the detection beam.
    We're working on updating the 3D design to reduce this possibility, but either way it's a good idea to check this before putting them in with mice!
  • Quick video
    Lex Kravitz02/01/2019 at 19:37 1 comment
    Quick video of sippers in action, showing water vs. chocolate
  • Rat v2.0 design coming soon!
    jkhokhar11/07/2018 at 19:06 0 comments
    We are getting closer to a finalized design for use with rats v2.0. Hope to upload it all here by the end of the month. This version has a much smaller footprint compared to the previous version. We are just working on finalizing the mounting via suction cups and the code for the volume measurement. Stay tuned!
  • Modification for rats!
    Lex Kravitz10/23/2018 at 23:07 0 comments
    Dr. Jibran Khokhar at the University of Guelph has modified this sipper device to measure liquid intake in rats.  Really cool!  He also added an eTape liquid level monitor to measure actual intake as well as the number of interactions with the sipper.  He plans to put the full design online soon, but in the meantime here are some photos!
  • TTL output when mouse interacts with sippers
    Lex Kravitz10/06/2018 at 17:12 0 comments
    We made a slight update to the code and design to give the sippers 2 TTL output connections that can sync sipper interactions with external equipment such as a fiber photometry or ephys recording system.  There is now an optional step in the instructions for which pins to solder these BNC connectors (to A1 and A3), and an update to the code to enable these pins as outputs.
  • Homecage validation!
    Lex Kravitz09/16/2018 at 14:33 0 comments
    We made some tweaks to the 3D design to allow the sipper device to mount onto rack-mounted vivarium cages.  This will allow for higher-throughput experiments.
  • First validation!
    Lex Kravitz08/15/2018 at 15:06 0 comments
    Earlier this week we assembled a sipper device and filled one tube with water and the other with diluted (1:2) chocolate ensure. We placed it in a mouse cage overnight.
    Some glamour shots of the device in a mouse cage:
    The next morning, guess what??  One tube was completely empty... the other untouched
    First data!
  • How much does this cost?
    Lex Kravitz08/11/2018 at 21:37 0 comments
    Not including the 3D parts, we calculate this at ~$85 per sipper.  This can be $30 cheaper if you don't need the battery, or just use a cheaper battery.  The $30 battery we chose was probably a bit overkill (6600mAh) but we had a bunch around the lab so we used them.  We're also thinking ahead to putting WIFI on this device for data transfer and that will require more battery power.  BOM in the files area as well.
  • Sipper video!
    Lex Kravitz08/11/2018 at 20:39 0 comments
View all 12 project logs
  • 1
    Print the two 3D parts
  • 2
    Prepare syringes
    Pull plunger out of 2 syringes and discard.  Cut the bottom off the syringes with a razor blade (see photo).  Epoxy a valve into the bottom and let dry fully. Drill a small hole in the plastic top.  Fill with water and check for leaks.
  • 3
    Put together 2 photo-interrupters
    Solder the PI into the Sparkfun breakout board, solder on a 1K resistor (the board says to use a 220Ohm resistor but we found 1K doesn't impair the function of the PI and consumes less power), and solder on the 3 pin JST connector. Be careful with the orientation of the connector, it's important!  Plug the wire into this 3 pin jack.
View all 11 instructions
Duncan wrote 03/08/2019 at 10:41 point
This looks great. I am trying to build some but am having trouble getting the Hydropac valves in Europe. I'm wondering if you have tried other valves or know of something I could try as an alternative?
Sophi Kravitz wrote 02/15/2019 at 17:35 point
This was a featured project today on Hackaday.com, congrats!
