ElektroCaster
An open, modular guitar-design with some nifty features.
Public Chat
Compared to this whole world of electronic sound devices like eurorack-modules, drummashines and all this innovative stuff from big and small companies, the electric guitar market looks a little bit boring.
I play guitar but I also like those new ways of making music and I believe that a guitar could integrate great into an electronic music setup. It just needs a kind of redesign - what's technically possible shoud be done, as long as it stays to be a guitar.
Here is my proposal for an open, modular guitar-synth-design with some nifty features to make modern music.
This is mainly a Guitar but with a lot of unique features like an illuminated Fretboard and actuators to excite the strings.
Motivation
My two main driving forces to invent and build things are music and education. Often, my projects are to some extend usable in both areas. The ElektroCatser is a perfect example of that.
(Hardware-)Features and Design Goals
Here are some specs and design goals I have/had in mind when building the ElekroCaster. This list will evolve.
  • Maker friendly construction (3d-printer, CNC-Router, Vslots)
  • Modular construction and easy access to the electronics to make it a smooth prototyping platform (You'll be in like Flynn!)
  • Parametric OpenScad modelling (changable string count, scale, space between strings,...)
  • Playable like a normal electric guitar
  • Fully controllable RGB-Led-iluminated Fretboard (Only the first 17 frets for now, but easily exendable)
  • Touch-sensing-frets
  • Long scale (700mm) for low tunings
  • Two micros, one for audio an one for everything else.
  • Per string signal path
    • hexaphonic pickup
    • hex-preamp
    • Teensy 3.6 microcontroller
Here are some video Demos:
To learn more about this project and the design process, take a look at my project logs:
The Led-Fretboard
Touch-Sensitive Frets
Body-Neck-Construction
Audio Hardware
Connection and Communication
The KickUp
The MultEBow
Designing the Control Interface
Application Ideas
Power
Openness
This project is fully open source. It uses only open source libraries and all the design files can be opened with open source design tools. A git repository is also on the way to make this project better to collaborate.
View all 9 components
  • Exploring alternative Tunings with an illuminated Fretboard
    Frank Piesik03/21/2021 at 09:09 0 comments
    Alternative tunings can provide new perspectives on the instrument. I especially like open tunings because I like to play rhythmic patterns with open strings involved that move across the fretboard. But I rarely changed my tuning in the past, because it seemed hard enough to me to learn the fretboard as it is in standard tuning. This has changed since I implemented a polyphonic tuner function and the ability to change the root notes of each string with the corresponding encoders. See a first demo here:
    I really do enjoy the ease with which I can now discover foreign tunings and just play them immediately. I think using open tunings may now become an important aspect of my playing technique.
    Thinking one step further, I would be quite cool to utilize motor tuners to let the guitar completely tune itself. Since it has a Kickup, it could even excite the strings by itself. I actually already bought some motor tuners a while ago but I’m skeptical if the practical result will be worth the effort. It also would make the guitar even more top-heavy than it already tends to be.
  • ButtonsFaderSwitchesKnobsEncoderJoysticDisplay
    Frank Piesik02/02/2019 at 15:39 0 comments
    The title says it all: Here's a big update to my ElektroCaster!
    also, the project now has a home on github: https://github.com/fpiesik/ElektroCaster
    stay tuned for some music!
  • Power
    Frank Piesik10/22/2018 at 12:59 1 comment
    One design goal I have for this project is to make it a standalone intrument, meaning tha you don't need to connect more cables than the audio cable to the amp, to play with it. The only thing missing to get there is an integrated battery. But for now, I focus on optimizing the powering over the RJ45 cable, since this has to work also and should be used to charge the battery too.
  • Application Ideas
    Frank Piesik10/22/2018 at 11:30 0 comments
    Firstly, the ElektroCaster can be played like a normal (baritone-)guitar, which in itself I'm quite proud of. It's neck is admittedly kind of thick and I whish there would be thinner v-slots available (15x15 would be nice). But all in all, I really do enjoy playing it.
    Let's talk about what the ElektroCaster can do what others can't, by quickly sketch some possible applications. Some of them I allready have implemented and some are in the pipeline.
  • Designing the Control Interface
    Frank Piesik10/21/2018 at 17:47 0 comments
    Designing a control interface is arguably the most crititcal part when you develope a product. This may be especially true when designing instruments, with which you want to dive into sonic worlds and be in flow with the music. There is nothing more distracting if you have to think too much to achieve a certain effect. Thats why musicians have to practise so much.
  • The MultEBow
    Frank Piesik10/13/2018 at 07:42 0 comments
    "The EBow is a battery-powered electronic device for playing the electric guitar. The EBow uses a pickup – inductive string driver – feedback circuit, including a sensor coil, driver coil, and amplifier, to induce forced string vibrations. The EBow is monophonic, and drives one string at a time, producing a sound reminiscent of using a bow on the strings." (Wikipedia)
    The idea of the MultiBow, which I'm currently trying to realize, builds on this concept. It's essentially six EBows firmly installed under the strings. The allready installed hex-pickup serves as sensor coils and the driver coils are integrated with small class-d amplifiers into another pickup looking package. So the six signals from the pickup are going throug The Teensy-audio-board I use. It has 8 output-channels and I do only need one or two for the main output. One idea was to have additional discrete outputs for each string to process them externally. But using them as part of the MultiBow does make more sense to me, as it opens up the possebillity to modify the feedback signal to alter the effect on the strings (see moog guitar).
    Here is a little demo video to proof the concept:
  • The KickUp
    Frank Piesik10/10/2018 at 12:41 0 comments
    The KickUp is an actuator which includes 6 solenoids and a mosfet driver. It's used to hit the srtings from beneath - just the opposite of a pickup. Now the ElektroCaster can play semi-automatically (you still have to use the left hand). See the the KickUp in action in the sequencer video on the details page!
  • Connection and Communication
    Frank Piesik10/08/2018 at 10:15 0 comments
    Since this guitar is intended to be used in an ectronic music environment, it has to communicate with the rest of the gear, at least to get a clock signal on which it can synchronise it's actions.
  • Body-Neck-Construction
    Frank Piesik10/08/2018 at 09:35 0 comments
    I used three different types of components to build the basic shape of the guitar: 3d-printed parts, 20*20 VSlot profiles and plywood.
    My printer (Creality CR10S4) has build volume of 40*40*40cm. Beeing able to print the shape of a guitar body was the main reason I went for this big printer.
  • Audio-Hardware
    Frank Piesik10/08/2018 at 09:31 0 comments
    Here are some design goals for the audio part:
    • Discrecete audio path for each string to allow for independent audio manipulation.
    • Audio processing happens within the guitar, not on an external computer.
    • Latency under 5 milliseconds.
    • low power consumption to allow for battery operation.
View all 12 project logs
  • 1
    01 Preface
    If you want to build the ElektroCaster, here are some aspects you want to consider before you start:
    • This isn't for somebody who just want‘s to get the needed parts and assemble it like a diy-guitar-kit (yet). There will be some hurdles to take and difficult manual   labor to make.
    • Although this is a working prototype, this project is still (and may allways will be)  work in progress. Software and interface are hardly developed yet.
    • Think of it like a protoyping platform: wack in a new headstock with robotic          tuning features, try a new actuator beneath the strings or change the neck over an improved one – thanks to the modular design, all of this can be relatively       easy achieved.
    • There is not "the one ElektroCaster". It's parametrically designed in OpenScad, which is why many features can be changed: The number of the strings, the         length of the scale, the spacing between the strings (at neck and bridge             positions) or the number of frets can all be edited whithin the parameters.scad     file. That means, you could also make a small four-string-ukulele-version out of it.
    Tools that you might not have:
    • A big 3d-printer with 400x400x400 build volume, because there are many big  parts, which can't be split easily.
    • A cnc-router or laser-cutter wtih a build size bigger than the body (322x396mm).
    • A method to make the pcbs, I used my cnc-router.
  • 2
    02 The Slot-Body
    The core of the ElektroCaster is made of aluminum V-Slot profiles. I started whith a v-slot-starter-kit from RatRig, which I do recommend to get.
    For the slot-frame you‘ll need the following parts:
    • 3 x 50cm, 2020 v-slot profiles
    • 6 x M5, 40mm screws
    • 4 x M5 t-nuts
    And this tools:
    • Saw
    • Screwdriver
    • Tab to make M5 threads.
    1) Cut the profiles so that you end up whith the following lengths: 2 x 50cm(D), 2 x 25   cm(A), 4 x 12.5(B,C,E).
    2) Drill some 5mm holes to screw the parts A,B,C,D together. My v-slots allredy              came with threads on both ends but since you cut them, you‘ll need to tab some      threads to the A parts.
    3) Drill holes near the ends of E and use t-nuts to connect them to A and D. There        are no exact measures how to put them. They‘ll probably need to be adjusted          when mounting the printed body in the next step (which is no problem since the n    uts can be easily moved).
  • 3
    03 Print The Body-Frame
    1) Print the body.stl file (/hardware/mechanical/stl/body.stl). I used a .6mm nozzle,          .8mm extrusion width an .3mm layer height.
    2) Attach the printed body-frame to the slot-body using M5 screws and t-nuts. The       screws need to be cut to length.
    One screw doesn't need a t-nut as it's directly put into the slot-body. This screw is   one of those you allready used in step 2. I don't think this is really needed so I may   remove this in future versions.
View all 3 instructions
jonmuscat wrote 10/22/2018 at 15:31 point
Absolutely awesome Frank! The possibilities are endless. If you can get the platform out there and an SDK to make it easy for anyone to develop, it would do for the guitar world what the PC did for the IT industry. Maybe hardware kits while you sort out a finished product??
Mark Carew wrote 10/11/2018 at 14:53 point
Just want to chime in to say Frank this is an awesome build brother! Thank you for sharing hope your able to bring this to the masses for teaching.
z26 wrote 10/10/2018 at 21:54 point
Neat, I'm working on something very similar but I want to do an harp instead. (I'm not as advanced in the project as you are).  Single coil pickups can be found as low as 3$ online, so I was thinking of using one for each individual string.  So far my arduino uno can directly listen to the pickup, without any extra components.  The audio isn't good quality, but it's clear enough that I'll be able to play a guitar hero clone with the harp.
I'm still debating what I will replace the uno with.  Since I'll have at least 12 pickups, I assume I'll need two boards (2x the cost).  I don't need as much processing power than you (I want to plug in a pc, not an amp) but I do wonder what kind of quality I could get with a teensy alone (no board).
Alternatively, I could try multiplexing 2 pickups per pin which would half the sample rate of each one.  While the loss of quality of doing so is quite drastic for percussive instruments, it seems much less pronounced for guitar strings.
Good luck with your project
Brandon wrote 10/08/2018 at 18:58 point
Just wanted to chime in that this is sooo cool!
One thing that came to mind (from someone who has intermittently tried to learn the guitar) is to leverage this type of system for straight-up teaching of the guitar.
Also, I want to productize this something real-bad.  Do you have any interest in doing that?
Thoughts?
Again, so sweet!
Frank Piesik wrote 10/09/2018 at 08:08 point
Thanks!
Yes, the educational aspects of this project are very important to me too. I already have some ideas on how I want to use this for teaching...
I think this could be tailored for just this purpose and be quite inexpensive to produce. So yes, I'm basically interested to make a product out of this, but there are no concrete plans yet.
Brandon wrote 10/10/2018 at 04:16 point
Sounds good.  Well for what it's worth I'd be happy to help out.  I think this concept/product could sell well.
How I could potentially help:
1.  I recently met w/ an investment broker over an idea I'm currently prototyping.  He gave me the skinny on what all is needed in a pitch deck, and what will/won't fly.  Based on what you have I think it's enough to throw a pitch deck together and get funded to make this into a product.  (That, or Kickstarter.)
2.  I'm an EE.  So I can help productize that side.
3.  I happen to have a buddy who last year started a Industrial Design and Mechanical Engineering services company, so his business could definitely take the mechanical side through product.
Anyways, here if interested.  In the meantime I'm going to continue to do a slow/cumbersome job of writing Swift code (to make the proof of concept of my idea), until I can convince someone to do it for me.  ;-)
Cheers!
