• Results of Training the Customised Network
    Tegwyn☠Twmffat12/12/2018 at 13:57 0 comments
    I trained my first customised network, as designed in the previous log, on an Amazon AWS GPU and successfully got convergence, which means the network does work:
    Training took about 3.5 hours and it got an mAP (val) (mean actual precision) of about 10, which is not particularly good, but it's a good start. It's very possible that if I had kept on training that this might have continued to slowly increase, but my budget for this session was $10, so it had to stop!
  • Baby steps
    Tegwyn☠Twmffat12/11/2018 at 16:15 0 comments
    After messing about with some networks for a couple of months in an attemt to design computer vision for machines, I started to notice a few re-occurring topics and buzz words such as 'prototext' and 'weights'.
    Curiosity has now got the better of me and I worked out that the various prototext files associated with a network describe it's structure in reasonably simple and human readable terms eg:
    layer {
      type: "Pooling"
      bottom: "conv2/norm2"
      top: "pool2/3x3_s2"
      pooling_param {
        pool: MAX
        kernel_size: 3
        stride: 2
    I presume that this is a python layer, but I'm not sure, but it does not matter for now.
    The fantastic Nvidia Digits software enables print out of a fancy graphical representation of the whole network and, starting with the renowned bvlc_googlenet.caffemodel, I thought I'd try and hack it and learn something through experimentation.
    One of the first thing I looked for was symmetry and repetition, with the desire to simplify what initially look very complicated. I noticed that the above layer describes a 'link' between other blocks of layers that seem to repeat themselves about 6 times:
    ...... in the massive bvlc_googlenet network:
    ..... and in this way I managed to simplify it by removing what looked like about 6 large blocks of repeating layers to this:
    ...... And looking at this diagram very carefully, there's still one big block that repeats and should also be able to be removed. I tried removing it, but unfortunately gave this error:
    Creating layer coverage/sig
    Creating Layer coverage/sig
    coverage/sig <- cvg/classifier
    coverage/sig -> coverage
    Setting up coverage/sig
    Top shape: 2 1 80 80 (12800)
    Memory required for data: 851282688
    Creating layer bbox/regressor
    Creating Layer bbox/regressor
    bbox/regressor <- pool5/drop_s1_pool5/drop_s1_0_split_1
    bbox/regressor -> bboxes
    Setting up bbox/regressor
    Top shape: 2 4 80 80 (51200)
    Memory required for data: 851487488
    Creating layer bbox_mask
    Creating Layer bbox_mask
    bbox_mask <- bboxes
    bbox_mask <- coverage-block
    bbox_mask -> bboxes-masked
    Check failed: bottom[i]->shape() == bottom[0]->shape()
    ...... So that's it for now ..... and here's my 'simplified' network prototext for object detection:
    # DetectNet network
    # DetectNet network
    # Data/Input layers
    layer {
      type: "Data"
      top: "data"
      data_param {
        backend: LMDB
        source: "examples/kitti/kitti_train_images.lmdb"
        batch_size: 10
      include: { phase: TRAIN }
    layer {
      type: "Data"
      top: "label"
      data_param {
        backend: LMDB
        source: "examples/kitti/kitti_train_labels.lmdb"
        batch_size: 10
    layer {
      type: "Data"
      top: "data"
      data_param {
        backend: LMDB
        source: "examples/kitti/kitti_test_images.lmdb"
        batch_size: 6
      include: { phase: TEST stage: "val" }
    layer {
      type: "Data"
      top: "label"
      data_param {
        backend: LMDB
        source: "examples/kitti/kitti_test_labels.lmdb"
        batch_size: 6
    layer {
      type: "Input"
      top: "data"
      input_param {
        shape {
          dim: 1
          dim: 3
          dim: 640
          dim: 640
      include: { phase: TEST not_stage: "val" }
    # Data transformation layers
    layer {
      type: "DetectNetTransformation"
      bottom: "data"
      bottom:...
