Features:
- Samd11C14 32bit ATMEL ARM with USB bootloader
- easy update firmware, just plug to USB
- 2 x buttons +/-
- 1 x PWM power out
- 1 x analog input
- 20x Charlieplexed 3014 leds
- missing segment F on first digit, you can display only numbers from 00 to 399
for full display needed 21LED bud charlieplexing with 5GPIO can drive only 20leds - easy pack in heat - shrink tube
- based on DIXI https://hackaday.io/project/10210-dixi-arduino-sam-d11-usb-stick
bobricius
Kuldeep Singh Dhaka
CLANDESTIGN
Stefan Wagner
Klaus Betz
What's the precison of the temperature control? The cold junction isn't measured, right? Or do you use the controller internal temperature sensor? Some of the SAMD have terrible tolerances on those as well!
