The space anemone is made up of a freeform circuit above the surface, and a Raspberry Pi and power board below the surface. The freeform circuit consists of LEDs, an LED line driver, an ADC, a shift register, MOSFETs, photoresistors with heat-shrink and a thermistor. It is inspired by anemones (the flower) and sea anemones.
Michael Barton-Sweeney
blinkingthing
arturo182
ric866
This has such a great look! What did you use for the clear dome?
