USB-C-PD Soldering Pen for Weller RT Tips
Small and powerfull controlling unit powerd from USB-C-PD
Public Chat
This is my project to build a controller unit for the Weller RT-tips.
The intention for this project was to built a cheaper and even more compact
controlling unit for one of the best soldering tips for small and medium sized soldering joints. It aims to professionals who not want to pay from around 700€ for a big controlling unit but also like the professional feel and results of these tips. Another big benefit is the high variety of different tips.
By the time this project wasn't cheaper than buying a finishend Weller station, but I still have lots of fun working on this project. However, I have a soldering pen which fulfill all my needs!
Soon everybody can have one because I will share the production files.
I'm very glad that my project made it into the top 20!
Enjoy looking around on my project page and feel free to like and leave comment!
Ideas for improvements are welcome :)
I have used the PD 3.0 with 9V/3A for supply. It can be powered from an USB-PD power supply (even suitable laptop USB-C power supplies) or with an PD-Power bank for soldering on the go.
The heat up time from 25°C to 350°C is around 6s. Auto-standby temperature is around 180°C, by picking up from the rest around 3s are needed to reheat.
The main goal by the designing the PCB, Enclosure and UI was not to exceed the diameter of rubber grip to keep it as small, handy and portable as possible.
The user-interface consist tree LED's and two buttons. The LED's indicate which temperature profile is active (Low, Mid or High) as well as the operating modes (user-standby, auto-standby, auto-off, warm-up and overheat).
Its UI is simple! - If any LED blinks, the Soldering Pen is not ready or at the desired temperature range. Steady light than means that the pen is ready.
I have chosen the simple 3-LED-Display because there is no need to set or know the temperature in 1°C steps. There are three basic groups of soldering types:
- Very sensitive components(e.g. temperature sensors)
- Regular sensitive components and Wires (e.g. Resistors, Capacitors, most types of IC's)
- Not sensitive parts (e.g. large copper areas)
Based on this knowledge I implemented the three profiles.
One button controls the user-standby mode the other changes the temperature profiles.
The pen fits perfectly in the original Weller safety rest WDH 51.
When it comes to a regular transportation (eg. in tool cases) weight ist very important. The soldering pen itself wights around 9 grams, with tip (RT1) 19 grams. Complete set with soldering pen, tip, cable and power supply (DA45C) is just around 150 grams! Less than a modern smartphone.
Here are the video demonstrations:
Adobe Portable Document Format - 799.84 kB - 09/30/2019 at 19:44
Preview
Download
RTPD1-SW_v3.hex
Software for the Soldering Pen
hex - 34.13 kB - 09/30/2019 at 09:56
Download
plain - 245.00 bytes - 09/30/2019 at 09:49
Download
Development and Prototype history.pdf
This document shows every prototype stage in the past with its requirements.
Adobe Portable Document Format - 1.17 MB - 09/30/2019 at 08:35
Preview
Download
Portable Network Graphics (PNG) - 17.71 kB - 09/30/2019 at 08:28
Preview
Download
View all 13 files
  • 1 × STM32F042G6U6 MCU
  • 1 × DMC1016UPD-13 Dual Mosfet
  • 1 × LM3480IM3-3.3/NOPB 3V3 regulator
  • 1 × F721A108MMCAQ2 1000µF Cap
  • 1 × STUSB4500QTR USB Controller
View all 6 components
  • New photos and size comparison
    Thomas Leputsch09/20/2019 at 17:19 0 comments
    I've done a side by side photo of the RT Pen and the original Weller.
    When about the half wattage is enough, much table-space and cash can be saved with RT Pen. The RT Pen includes every feature for hobbyist usage.
    I've tested the the RT Pen with the new GaNFast power supply from AUKEY (PA-Y21) with 30 Watts. Worked fine, and is even smaller and more lightweight than the used from ARTSYN power supply.
    Here are some photos of the comparison:
  • New housing just arrived
    Thomas Leputsch09/17/2019 at 15:11 0 comments
    The order of the 3D-Printed cases just arrived. I'm very impressed by the precision and surface.
    The three joints from the cap to the main body printed as expected. To remove them just cut them near the cap than  do break/cut the remaining joints off with a small flat screwdriver. Very easy and time-saving when doing larger batches.
    The parts are made of Nylon and have a nice semigloss black finish with an rough surface which has a very good grip and feel. No fingerprints are visible on the surface.
    For now I used the not so nice cut old stickers I had here but im currently working on new one.
    The sticker at the USB-C side also secures the -already tight in place- cap from falling off.
    Here are some photos:
  • Composition of Parts
    Thomas Leputsch09/13/2019 at 13:39 0 comments
    With the PCB already inserted, the following animation shows how the remaining parts are put together.
  • Professional MJF 3D-Print
    Thomas Leputsch09/11/2019 at 10:56 0 comments
    New, slightly improved design is just put into production in a professional 3D-Printing house.
    I've chosen Nylon PA12 with an 80µm layer height in semigloss black.
    The prize @100 pcs. comes down to a few Euros.
    This is a render of the current CAD model. Optimized for one-print-job.
  • Improved cap design
    Thomas Leputsch05/04/2019 at 15:48 0 comments
    With the new design the cap can be hold in place by the top-sticker or additionally with a wraparound-sticker. Fits perfectly now with the USB-C.
  • Just soldered some boards
    Thomas Leputsch05/03/2019 at 17:04 0 comments
    All new PCB’s are fine. Just a little SW adjustment due to a new OPA.
  • 3D-Printed transport case
    Thomas Leputsch04/04/2019 at 20:05 0 comments
  • Silver edition ;-)
    Thomas Leputsch03/01/2019 at 18:49 0 comments
  • New 3D Print
    Thomas Leputsch02/24/2019 at 15:08 0 comments
    This is the current version of the housing, now with labels on the buttons. The button size is also increased for better pressing feedback.
    Outer diameter of the housing now is 12.5mm. Nearly the same as the rubber grip on the RT Tip.
  • USB Virtual COM-Port and housing
    Thomas Leputsch02/17/2019 at 15:40 0 comments
    Just finished programming the USB connection directly from/to the STM32. Next step will be to implement an emulated EEPROM because there in no dedicated data EEPROM on the used STM32.
    New housing design is also finished.
View all 11 project logs
Mike Szczys wrote 02/11/2019 at 23:23 point
I feel like there must be cellphone MFG cables that are USB-C and silicone insulated but don't know for sure (my Pixel cable is not).
Would love more information on this. Is it a pain to work with those connectors? How about negotiating with the power supply.
Demo video and case looks great! You could put a rectangle of tinted acrylic over the flat area of the pen with beveled edges and holes for the buttons and you'd have a killer finish!
Thomas Leputsch wrote 02/12/2019 at 06:43 point
Thanks for your comment!
For soldering the USB-C connector an oven is needed due to the inaccessible pads in second row. I’ve used a stand-alone controller for negotiating the supply - it was a bit tricky to configure but finally it worked good.
More information is coming!
New 3D Print Design and hopefully a working USB 2.0 communication via the USB C Port.
Its planed to cover the full flat side with a sticker but in this version I’ve just used the middle part to hold the diffuser in place. Maybe I can implement a tiny sticker on top of the buttons.
Regards,
Thomas
Mike Szczys wrote 02/12/2019 at 15:34 point
Oh, interesting. What kind of functionality do you have in mind for the USB 2.0 connection?
