Now with Home Assistant control
02/23/2022 at 20:01 • 0 commentsSince having originally created this project, I've discovered the amazingness that is Home Assistant.. I'm all-in on HA and am slowly including my homemade projects into it by adding the necessary code. I've uploaded the modified code to Github and renamed it since most folks probably won't care about this part.
If you aren't familiar with Home Assistant, check it out!
New project!
12/04/2019 at 19:51 • 0 commentsI created a mission control 'console' for controlling this project, and created a new project page for it. Check it out!
Update to LM Mount Piece
07/26/2019 at 00:21 • 0 commentsAfter a month+ of periodic removal and usage, the attachment point between the LEGO LM and the LM Mount printed piece got loose enough that the LEGO easily tipped. I adjusted the dimensions just a tad and it is now quite snug. All files on Thingiverse have been updated accordingly.
