Can I... Can I touch it?
I finally got around to shooting some video of a project using this board.
The synchronous conversion is complete. The only thing untested is the NVM burn feature.
Post title says it all. :-)
Published kicad src last night. Gerber generation is easy from there.
If you want to buy one, I was thinking of making this my inaugural offering on Tindie. But it would likely be faster to order it off Osh and hotplate it yourself.
The SX8634 is a bit pricey for what it does, relative to other similar parts from other vendors. But I have zero complaints with this part so far.
I've found no mistakes in the datasheet (which is clear and complete), and the board performs beautifully.
The only driver I have written for it is for ManuvrOS. But an Arduino port wouldn't be difficult.
You bet. :-)
Here is my fully-functional driver for the part. As I said, it isn't as easy as Arduino, and a port is probably forth-coming. But it should help you see what the thing can do.
https://github.com/Manuvr/ManuvrOS/tree/master/ManuvrOS/Drivers/SX8634
Cool!
What about gerbers?)
