When assembling smaller quantities of PCBs you typically do not order entire SMD reels. Mostly you get plastic bags with maybe a few hundreds of 0603 resistors, capacitors and other components.
But how do you organize them? Searching for the right component often is just a pain. And if you forget to put them back into the bag after you placed em on your board you'll end up having multiple strips of unlabelled components.
To fix this I used Fusion 360 to create some sort of magazin to hold these component strips.
These magazines are equipped with a clamping mechanism so you can attach them to a rail.
That makes them stable on your desk and enables you to pick and place components pretty quickly.
I made a full video describing the features and benefits of this project.
It also includes how you can 3D print those for your own shop.
Happy hacking!
Robin Reiter
Bhavesh Kakwani
chmod775
Ian Dunn
Alan Green
HERE: https://www.thingiverse.com/thing:3952021
It's something of an oversight that neither the Instructions PDF nor this page, have any link to the 3D shape files. I assume it used to be here.
