I wanted to design my own 3D Printable Mini ITX computer case as I couldn't quite find one that I wanted on Thingiverse already.
The main idea of this case is that it's designed in modules so you can print the segments you require for what your needs are.
The target is less than 1KG / 1 Spool of fillament.
