Arduino controlled photogrammetry 3D-scanner
A completely automated way to take photo's and convert them into a 3D-object
This turntable is a new and improved version of my hand cranked version (which is fully 3D-prinable, no extra parts needed. Check it out here: https://hackaday.io/project/166323-fully-3d-printable-turntable).It uses an Arduino UNO to control a 1602 LCD screen, a stepper motor and a 9g servo motor. The turntable can be used as a 3D-scanner by taking photos of an object 360 degrees around it. These photos can be converted later on into a 3D-model using photogrammetry software. The amount of photos that have to be taken can be determined by the user, ranging from 2 photos to 200 photo's (can be easily adjusted in the arduino program). The turntable can also be used to take cinematic shots. In this mode the turntable rotates at a constant speed chosen by the user. The last menu enables the user to manually move the turntable.
As said before this turntable is a new and improved version of my hand cranked version. A lot of people suggested to me I should put a stepper motor onto it to get some very nice cinematic shots. This is exactly what I did.
I gave it a bit more functionality than just a regular cinematic turntable. I added the possibility to use the turntable to capture photos 360 degrees around an object.
The photos are being taken by a smartphone connected to a Bluetooth remote located inside the turntable. I just used the most straight forward, obvious and simple solution to capture these photos, which was to use a servo to press a button on a Bluetooth remote. I went for this solution due to the fact that Apple products tend to not like the HC-05 and HC-06 Bluetooth modules and refuse to connect to them. I’m sure a cleaner and more durable solution is to use these HC-05 or HC-06 modules and connect them to an android device.
The amount of photo's that have to be taken can be determined by the user, ranging from 2 photo's to 200 photo's. These values can be easily adjusted in the Arduino program. The taken photos can be converted later on into a 3D-model using photogrammetry software. The photogrammetry software I use is Autodesk Recap Photo.
In the second menu you can find the possibility to use the turntable to make awesome cinematic shots of your objects. In this mode the turntable rotates a certain amount of turns at a constant speed chosen by the user ranging from 1 to 17 RPM (speed of the stepper motor).
The third and last menu enables the user to manually control the turntable and bring the plate to the desired position at the preferred speed.
All the mechanical parts of this turntable are completely 3D-printed. The bearing for example is a print-in-place one which works great for this application. The print in place of moving objects adds to the simplicity of the build
STL-files can be found here: https://www.thingiverse.com/thing:3958326
Video can be found here:
wiring diagram for the turntable
JPEG Image - 174.17 kB - 11/05/2019 at 21:03
Preview
Download
Camera_Turntable_Arduino_expansion_Final_version_1.ino
Arduino program for the turntable. It works but keep in mind there is room for improvement.
ino - 12.15 kB - 11/05/2019 at 21:02
Download
View all 8 components
View all 2 project logs
  • 1
    Step 1
View all instructions
jrweikle wrote 7 hours ago point
what is the pot for?  and what value is it?
Brian Brocken wrote 7 hours ago point
The potentiometer is there to adjust the brightness of the backlight of the lcd. I used a 10K one.
thanks i thought so but was unsure without the data sheet
Hexastorm wrote 4 days ago point
Thanks for sharing this! Could you do some measurements on the accuracy of your stage.
The most familiar stage I am aware of are the heavy duty rotation stages of thorlabs see https://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=1064 . They costs like 2500 euro.
Could you share the accuracy and bidirectional repeatability. I understand you can't reach the specifications of thorlabs but it would still be interesting to know what you can achieve with this setup. Personally, i also think arduino is non sensical. The only thing what is important is the motor and stepper or servo driver you use. I would use a nema 17 motor and at at least something like TMC2130 or TMC2160.
Design looks real nice!
Brian Brocken wrote 3 days ago point
Hello, I did some quick calculating for you to get a rough idea on the accuracy. The stepper motor used takes 2048 steps to get one full rotation. The gear ratio between the small gear and larger inner gear is 1:7. So the larger inner gear needs 14336 steps to get one full rotation. One step would then rotate the larger inner gear by 0.025 degrees. 0.025 would equal about 436 µRad. This is a purely theoretical calculation, please keep in mind the bearing has a play of about 1 to 2 millimeters and there's also some play between small and larger inner gear. I really wouldn't know how to measure or calculate the bidirectional repeatability, I also don't think I have the right equipment for this. I wouldn't recommend to use this as servo or something similar as the 3D-printed bearing has to much axial and radial play. It's more then perfect for the turntable but not for a servo. If I where you, I would consider using some real bearings and create a custom design for your application. I think the right combination of 3D-printed parts and some real bearings could give you some good accuracy and repeatability. Of course not as good as a completely mechined one, but close enough 😜👍
Arye wrote 5 days ago point
I wonder how many kg's this pretty thing can hold being printed with pla. The latest cylinder structure seems quite solid.
Brian Brocken wrote 5 days ago point
Hello Arye, it obviously isn’t intended for larger objects (they wouldn’t fit on the plate either) but more for smaller objects like action figures, small 3D-prints,... However, all the objects i put on the table so far didn’t seem to cause any problems. The servo i put on it is quite substantial and was about the max size of the plate and it worked great😁👍 I also forgot to mention in the details I added some fine machine oil to the bearing to get rid of the friction which seems to work very well 👌😁
I wouldn’t go over a kilo though 😬😁👍
The strength of the PLA isn’t going the cause any problems in this project, the strength of the stepper motor is 😅
Dan Maloney wrote 11/06/2019 at 16:04 point
Nice build! In the video, the servo had me confused at first - I thought it was somehow locking the turntable for each shot. Then I saw the Bluetooth remote - clever! I've got a build I need to do that requires button-pushing like that - thanks for the idea.
Brian Brocken wrote 11/06/2019 at 19:17 point
Thank you Dan! I would've preferred to use a less mechanical sollution to take the photos, but Apple product just don't like to connect with bluetooth modules like the HC-05 and HC-06. My first idea was to open the bluetooth remote up and extend the contacts of the pushbutton to the arduino, but the pushbutton turned out to be a capacitive or magnetic one like the ones you can find on calculators or keyboards. So the servo pushing the button turned out to be the easiest most straight forward sollution, I mean if it works, why not haha ;-)
Tom Nardi wrote 11/06/2019 at 16:04 point
Awesome to see the design evolve. Would have been interesting to have it use the same bearing as the manually cranked one so it would be an easier/faster upgrade, but the final product definitely looks better without having the circular mounts for the legs and crank on the sides.
Brian Brocken wrote 11/06/2019 at 19:10 point
Thanks Tom! Yes i also would've liked to keep the same bearing as the hand cranked one but I had to change to much to the design in order to place all the electronics and motor etc inside it. And like you say the circular leg holders were in the way and I had to delete them. The plan was to just add a motor to it, turned out to become a completely different design haha ;-)
