The Mask
Glowing Low Poly Mask ..... for raves and such
A mask covered in programmable RGD LEDs
Draws about 5A at full blast
JPEG Image - 2.56 MB - 01/12/2020 at 13:57
Preview
Download
quicktime - 10.88 MB - 01/12/2020 at 13:57
Download
JPEG Image - 1.71 MB - 01/12/2020 at 13:57
Preview
Download
  • The Beginning
    alexleffell01/12/2020 at 17:45 0 comments
    So one day my friend show'd me some paper-craft masks she made from wintercroft templates. I immediately thought I had to make one covered in LEDs.
    After downloading their design for the Fox Half Mask I opened it in Fusion360 so I could copy the outline for each polygon in to a DXF before transferring that to Altium. I thought for a while if there was a more efficient way to layout approximately 400 LED's, but since each polygon was different I ended up just doing it by hand while watching the entire second season of Succession.
    [insert altium pic]
    In order to make things slightly simpler, I sourced the 5th version (with integrated bypass caps) of the WS2812B directly from World Semi.
    Many hours later I fired off an order to JLC. A few days after that I got these guys:
    [board pic]
    I didn't take many progress pics, but I laser cut a kapton stencil, did the whole reflow thing and then singulated each polygon with a bandsaw. In the future I'd pull the ground and power pours further back from the edge so they don't get exposed when cut.
View project log
