This project takes a look at using one of the two Cypress PSoC 6 wireless kits to connect to the AWS IoT cloud. Using MQTT with TLS, we then publish some data collected from a light sensor. The project goes step-by-step over getting AWS IoT set up (not an easy thing without instructions!) as well as modifying the example code Cypress provides to publish our collected data.
Alexander
Pranav Gulati
Willem Jan Faber
mihai.cuciuc
JayeshRajam
@Alexander, Bigly Thanks!!! Saved me countless hours of reading and trial and error, I am publishing and subscribing, sending commands to my device via IoT Core!
William
