• RADIO
    ACMEDEFENSECORP05/17/2020 at 07:52 0 comments
    ALL WE HEAR IS RADIO GAGA
    Since I didnt really learn electronics at school, I expectef the radio to be quite difficult to build. but it turned out easier than I thought, it's just a basic button box, with an Adruino, a screen, a 2.4GHz module and a battery of course. The box is 3D printed (SLA) and the pannel is made out of wod, laser cut.
    HOMEMADE BRIDGE DIVIDER
  • CHASSIS FRAME
    ACMEDEFENSECORP05/16/2020 at 19:18 0 comments
    GETTING THE RIGHT FRAME OF MIND
    Building the frame wasn't that hard, but much longer than i expected. Mainly because i had to drill hundreds of holes and be very cautious with positioning and maintaining the struds carefully, after some sort of misadventure. The chassis is not finished yet.
    OOPS.....
    MUCH BETTER
  • GEARBOX, Mk1
    ACMEDEFENSECORP05/16/2020 at 17:20 0 comments
    FULL SPEED AHEAD !
    The gearbox design has been quite a challenge : I have a lot of mechanical power to transmit (4.8kW) with a high speed on one side and high torque on the other. Not to mention that the gearbox had to be as compact as possible to fit in the tank. I used roller chains instead of gears to make it easier to assemble run and service, as is it my first gearbox project.
    CAD
    MATH TIME
  • EARLY DESIGNS
    ACMEDEFENSECORP05/16/2020 at 17:06 0 comments
    Because history matters
