Vacuum Arc Printer (Proof of Concept)
To solve the EMI and oxidation problem from the last design I want to try operating the machine in vacuum.
Public Chat
In this project I want to build an open source metal powder printer that uses an arc instead of a laser, because an metal melting arc can be created with simple electronics which are much more affordable and also safer to handle than a high power laser.
I'm currently working on a design that operates in an inert vacuum environment to get oxidation free metal parts.
IRFP460 Board with ESD Protection
  • Effect of Vacuum on Oxidation
    Dominik Meffert6 hours ago 0 comments
    Because I ran out of shielding gas I wanted to figure out how the atmospheric pressure affects oxidation and so I performed two tests one at normal atmospheric pressure and one at -20inHg, both without shielding gas.
    Test at normal pressure:
    Test at -20inHg:
    You can see the difference between both videos while melting and on the melted spot.
    At normal pressure the powder is sparking and smoking while being heated and after melting you can see the brown oxidation.
    At -20inHg the heating reaction is less intensive and after melting there is no such sign of oxidation.
    Both tests were performed without shielding gas. Because of the good result with the vacuum it could be possible to do it completely without shielding gas. I would really appreciate that because purging an 80L chamber needs a lot of shielding gas and shielding gas is not cheap, so the entire process would be a lot less expensive without it.
  • New Power Source
    Dominik Meffert15 hours ago 0 comments
    While testing out the new vacuum chamber I figured out that in contrast to the smaller vacuum chamber I could not reach the needed vacuum level to ignite the arc with 780VDC from the voltage doubler.
    So I tried out whether it would be possible to melt the metal powder with a ZVS driver driven flyback transformer and in contrast to the single MOSFET flyback driver that I tried out before the ZVS driver could deliver enough power to melt the metal powder by its own.
    Using the ZVS flyback would have the advantages, that it can melt the powder by its own so that the welder circuit would no longer be needed (only the flyback transformer, ZVS driver and a relay/mosfet), that it creates less EMI than the ignition coil arc starter and that it can ignite the arc by its own.
    In term of the vacuum, I think it would be the best to keep it just low enough that the chamber stays sealed to keep everything simple. Doing so could make it possible to use just mechanical seals to bring the motion inside the chamber or even use stepper motors inside.
  • New Pump and Vacuum Chamber
    Dominik Meffert16 hours ago 0 comments
    To test out the operation of a 3D printer in low vacuum purged with shielding gas I got a new 80L vacuum chamber with enough space for a small 3D printer.
  • Magnetic Shaft Coupling
    Dominik Meffert12/24/2020 at 14:49 0 comments
    For bringing the motion of stepper motors inside a vacuum chamber while keeping everything sealed I want to try out using a simple magnetic shaft coupling. Here is a quick test of some parts.
    I used 12 pieces of 10*3mm neodymium magnets, a 608ZZ bearing and a 3D printed spacer + magnet holder/shaft for each half.
    The two halves are attracted to each other very strong and there is a lot of force required to move one half while holding the other one. The magnetic coupling can be increased by stacking more magnets on top of each other, so that rather the stepper motor skips than the magnetic shaft coupling.
  • Oxygen and Pressure Control
    Dominik Meffert12/20/2020 at 12:24 0 comments
    To prevent oxidation and forming of gas bubbles in the later parts, I want to have the possibility to measure and control the pressure and oxygen in the vacuum chamber and so I added some parts:
    A pressure sensor with a range from 0 to -101kPa and an output from 1 to 5VDC.
    An oxygen sensor with a range from 0 to 25Vol% and an output from 9 to 13mVDC.
    Better cable entrys made of 1/4 to 3/8" fittings + cap with a hole in it sealed with hot glue.
    A small 12VDC air pump to pump the chamber's atmosphere to the sensor.
    And some other parts including 3 solenoid valves, a one way valve, tube connectors, a separate chamber for the oxygen sensor and pump and another cable entry.
    Measuring the pressure from 0 to -101kPa to get a 1 to 5VDC output is very easy with the pressure sensor.
    Not as easy is measuring the oxygen level.
    I looked for oxygen sensors which can work in a vacuum and figured out that they are very rare and expensive. There are the zirconium ones which I could find only for business customers for multiple 1000$ and the optical ones with fluorescent patches and scanners which I also could not find for private customers with the same high prices (The patches are a bit cheaper).
    So I decided to buy a much cheaper galvanic cell type oxygen sensor that works from 700 to 1750hPa. This type of sensors get used for critical applications like ventilators, diving rebreathers and car exhaust measurements and should therefore be accurate enough for this application. The sensor got placed in a small chamber made from HT 75 pipe, that is separated by two solenoid valves from the rest of the system.
    Measuring Oxygen:
    To measure the oxygen level the machine should perform the following tasks:
    - Turn on the vacuum pump to get the vacuum chamber to the lowest pressure level and turn off the pump when pressure is reached.
    - Open the shielding gas solenoid valve to fill the vacuum chamber back up again until the pressure is >700hPa and close the valve when pressure is reached.
    - When the pressure is ≥700hPa open the two solenoid valves to connect the oxygen sensor chamber with the vacuum chamber and turn on an air pump to carry the vacuum chamber's atmosphere to the oxygen sensor. 700hPa should still be enough negative pressure to keep everything sealed so that no air can enter the system.
    - Wait some time to perform the measurement.
    - Bring the vacuum chamber back to the lowest pressure.
    - When the pressure is <700hPa close the valves and turn off the pump.
    - If the oxygen level is OK start/continue operation.
    - If the oxygen level is not OK repeat the measurement or hold the program and show an error (The same with unexpected pressure readings and timeouts).
    At the moment the system is untestet and I still need to build a controller for the system with relays for the solenoid valves and pumps and an amplifier for the oxygen sensor (the pressure sensor can be measured directly by the microcontroller).
    Hope that it will work as planned :)
  • Vacuum Arc Experiment
    Dominik Meffert12/07/2020 at 06:19 0 comments
    I wanted to create an arc in vacuum with moderate voltage (up to 650VDC), so I bought a vacuum pump.
    Next I started working on a vacuum chamber.
    After many unsuccessful designs I could finally get something to work.
    With this design I could achieve a pressure less than 1mbar, so the next step was to produce a measurable voltage for testing.
    After some unsuccessful tries with voltage multipliers and flyback transformers, I built a voltage doubler which outputs around 630VDC while applying 230VAC.
    A reading of 625VDC and some lightbulbs as resistance for testing.
    Here is a video of the experiment. After selecting 230VAC on the variac and turning on the vacuum pump it took a while to get the pressure and with it the breakdown voltage low enough for the arc to ignite and the lights to turn on.
    The next step could be building another vacuum chamber with a larger window and buying a new pressure gauge that can read the actual pressure, also measuring the arc length, voltage and current and also trying to melt some metal powder.
    For some reason I was not sure whether there was also heat created with this experiment, but by the later inspection of the screw terminal and wire, signs of heat and melting were clearly visible on one side.
  • Vacuum
    Dominik Meffert12/07/2020 at 01:01 0 comments
    Some time has gone since the last update.
    In the last few weeks I had not much time to work on my projects because I moved to a new location, but the work is almost done and I can continue working on stuff.
    So I will continue with this project and will try to fix the problems which I had not solved in the past, which are:
    - Oxidation, because of the lack of a controlled inert atmosphere.
    - High EMI noise, what made the use of sensitive electronics like sensors and microcontrollers almost impossible and required elaborate signal transmission over optical cables from a distance or complicated shielding of all parts.
    - Going 3D, with a SLS style recoater and piston sytem.
    - Control of all parameters, with an inverter based power supply and a few sensors.
    I recently had an idea that could solve these problems:
    Vacuum
    I learned that the breakdown voltage of a gas decreases in vacuum described by Paschen's Law.
    So if the pressure and electrodes distance would be low enough and the applied voltage would be high enough an arc would ignite without the need of an EMI emitting high voltage source and as there are vacuum arc furnaces out there it should also be possible to reach high enough temperatures to melt the metal powder.
    IGBTs and MOSFETs which can switch up to 1000V are also easy available.
    I think the challenging parts while building such a vacuum arc printer would be the construction of a large enough vacuum chamber which can fit a 3D printer and the problems caused by the vacuum like the reduced breakdown voltage and outgassing what would make the use of electronics like sensors, stepper motors and some materials like grease and maybe rubber impossible.
    My current plan is to
    use a piece of large construction steel pipe (>500mm inner diameter with 5-10mm wall thickness) with machined acrylic or aluminum top and bottom,
    or welding of a steel or aluminum box with 5-10mm wall thickness,
    or less likely glue together an acrylic box with >20mm wall thickness,
    everything in combination with a good vacuum pump that can achieve less than 1mbar.
    To solve the breakdown and outgassing problem I thought about bringing the motion from every stepper motor placed on the outside of the chamber into the inside by the use of a shaft sealed by a mechanical seal.
    For detecting the limits of the axis I would use Trinamics StallGuard/Sensorless Homing feature.
    I think if everything should work it could be a very interesting machine at the end.
    So that's the plan and now the work can begin.
  • Heat resistant Electrode Holder
    Dominik Meffert10/29/2020 at 16:11 0 comments
    For further testing a heat resistant electrode holder is needed which can handle the temperature of multiple hundreds degrees while staying cold enough to be mounted on 3D printed parts.
    So here is my attempt of building one.
    It's made off a cross fitting, hose connectors, hydraulic fittings and a brass tube, what keeps the electrode holder water thight while offering space for the tungsten electrode.
    The plan is to keep it cold by a constant water flow through it. Maybe by using some thermal paste it could also keep the electrode a bit cooler. The electrode is loose inserted into the brass tube. There should be around 0.3mm of space between electrode and the inner wall of the tube.
    The electrode could be fixed by a clamp at the upper and lower end of the brass tube.
    The X Carriage for scale. All parts are 1/8" BSP size. Only a 3D printed mounting bracket and a hose connection is missing.
  • DC Side Switching
    Dominik Meffert10/23/2020 at 03:17 0 comments
    I've built another MOSFET board for switching of the DC side to make very fast switching of the power source possible.
    I tested it out and realized that the too long ON-times which I thought were caused by the rectifiers capacitor were still there and therefore were caused by the GCODE.
    So better GCODE is needed.
    I ordered some fittings, which I want to use for building a watercooled electrode mounting bracket. They should arrive by the middle of the next week.
  • Testing everything together
    Dominik Meffert10/18/2020 at 03:13 0 comments
    Now that the arc starter, arc power, stepper driver and printer controller work it is time to test everything together.
    In this test I tried continuous mode for melting the powder. The result looked good but was only partially melted solid. By trying out a lower moving speed the result got not really better but the tungten electrode melted due to the heat and no cooling. The 3D printed mounting bracket also melted, what was ok, because it was not designed to withstand high temperatures. I think I will design a watercooled all-metal toolhead in the future which can handle the temperature and prevent the electrode from melting.
    I did another test and this time I tried to print a dot matrix with the idea that multiple dots  placed close to each other can create a solid structure, which was the case.
    I think with this method the amount of heat/energy can be controlled more precisely than with continuous mode:
    I could be wrong, but I think with continuous mode there would be only the power (Amps/Voltage Setting) and the moving speed adjustable and with dot matrix mode there would be also the exposure time and space between dots adjustable, what I think could lead to a more precise and reproducable heating. I think it would also be possible to add short cooling time between the dots to prevent the heat from the pulses from adding up on each other what could prevent overheating of the electrode and spreading of the heat in the powder. Maybe doing so could also reduce the width of the printed lines, what would lead to more pecision.
    First printed single layer object - there is plenty room for improvements :)
    I think a thing that has gone wrong in this test was that the switching of the welding power has been slower than the actual setting. The cause for that is, that I'm currently switching the AC side with a SSR before the rectifier and its capacitor which has to charge and discharge, what I think is slowing down the switching time.
    I did that because the SSR was the only semiconductor part which not got destroyed from the arc starter.
    I replaced the continuous arc starter with a single pulse arc starter a while back and did not try another MOSFET out. Maybe it would work with the new arc starter and I will test it out in the next few days.
    Fried MOSFETS were a huge problem in the construction of this project.
    The first time I got the new arc starter to work the MOSFET got fried after some time, I assume from ESD on the gate.
    I designed a new pcb with four 7.5V zener diodes between gate and source to clamp the voltage to 15V and two 265V TVS diodes between drain and source to clamp the voltage to 265V. The MOSFET is a IRFP460 driven with 12V.
    This MOSFET board switches the arc starter and maybe such a board would also work for the arc power.
    I hope this design will last long, because I have no idea what else I could do to prevent the MOSFET from dieing.
View all 17 project logs
Dan Maloney wrote 10/29/2020 at 21:21 point
I've got an article coming out on metal additive manufacturing at JPL, and the printed parts on the Perseverance rover. A lot of the methods they use for printing remind me of this. Watch out for the article, you might pick up something from it.
Dominik Meffert wrote 10/29/2020 at 22:41 point
That sounds very interesting. Can't wait to read it :)
dekutree64 wrote 10/18/2020 at 01:41 point
Interesting idea. Sort of like electric discharge machining in reverse :)
Bharbour wrote 09/08/2020 at 16:16 point
There might be some useful ideas in this project: http://www3.telus.net/public/a5a26316/TIG_Welder.html
All the newer solid state (vs solid iron :) ) welders that I have looked at, control current by PWM on the DC output. They have enough inductance on the output of the circuit to keep the current rise rate within the bandwidth of the PWM and control hardware. I have done very small current sources (2 - 3A) with this approach and it works well. This approach keeps the power dissipation down to a reasonable level.
Dominik Meffert wrote 09/08/2020 at 17:34 point
Thank you very much for the link, I will check it out :)
Dan Maloney wrote 08/24/2020 at 20:38 point
I really like this idea, assuming that I understand it - you're basically sintering the powdered metal with the arc in a controlled fashion, right?
Have you thought ahead to how the Z-axis dimension will work? Seems like you'll either have to add more powder to the top or sink the growing print into the powder bed as you build up the print.
Dominik Meffert wrote 08/25/2020 at 08:27 point
Hi Dan,
Yes you are right. I want to try sintering the steel powder with an arc in a shielding gas chamber. For the Z axis I'm planning to build a printer with two pistons and a recoater like on a SLS printer, but first I want to test it with a single layer to figure out whether it is possible at all.
Dan Maloney wrote 08/25/2020 at 16:42 point
Good stuff, following with interest. I like this approach much better than the "CNC-MIG welder" ideas I've seen so many times. Seems more elegant.
