Random Generator
This is a digital random bit stream generator with a repetition time of 6’528 years clocked at 350 kHz.
0 followers
This digital random bit stream generator (RND192) uses a 56 bit long linear-feedback shift register (LFSR) with four taps on bit 56, 54, 52 and 49. The LFSR is clocked at 350 kHz.
On power up the 56 bits (7 bytes) of shift registers are initialized with random values which makes it a source of true random bits with a repetition time of 6’528 years.
Main product features
• True random stream.
• Internal or external clock for output synchronization.
• Can be used in analog or digital applications.
• Very low power consumption, max 4mA.
• Simple to use with only eight pins.
• No external components needed.
The random stream generated by the LFSR and the internal clock are two independent sources. The stream is fed into the D input of a D latch which can be clocked with an internal or external clock (see Fig 1.). The external clock can be any TTL signal up to 500 kHz. Pin-5 on low (zero) level select
datasheet-RND192.pdf
Datasheet for RBD192 - Random Generator
Adobe Portable Document Format - 259.00 kB - 10/24/2020 at 21:08
Preview
  • 1 × PIC16F15313
