Base plate of 1.8 mm thick plywood, here is where I will be mounting everything on
This is a test
Column attachment to the baseplate
Drilled and countersunk underside
Overkill? I think not!Normally I am a big (big!!) fan of Torx drive screws, and I have a lot of Torx head screws in storage, about 1700, but I didn’t buy thick and long ones. I had to use 5x80 mm Philips head screws instead…
Stoppers for the linear rails and not all screws are used yet because I will have to undo them anyways in a bit
Bottom view
Base rails to the base plank
Added trough bolts for more squareness and stiffness
Drilled and tapped
Table is mounted much more secure, I added a larger diameter for the fasteners connecting to the linear bearings, so my imperfections can pass trough without any issues of alignment
Of course i still have to tighten the nut, but I do that when I am sure that I like it this way
