HP printer cartridge control module
HP 63/302/123/803 cartridge control module with 3D printable mount.
Public Chat
The idea of this project is to make the MCU compatible control module for the HP printer cartridge in easy to connect format. For the first time ever, inkjet technology is available for your projects in a convenient module format with the necessary easy-to-use software. Most of the mechanical parts are 3D printable. The electronics part is a 23x38 mm level converters SMT PCB with 14 inputs with an overload cartridge protection circuit.
Synopsis
In my head quite often there are ideas that I would like to implement, they are both in the field of hardware and in the field of software. Often they remain unstarted because someone has already implemented them.
Once again I have a new idea - a project of a handheld printer which would consist of a color printer cartridge and optical flow sensor (the same which is installed in an optical mouse) in a compact case. My idea was that it would print by moving this whole construction over a sheet of paper. A genius idea, and... it already turned out to be implemented, for example here: PrintCube.
Okay, let this particular idea has already been implemented, but many more interesting things can be done based on printing:
  • Make DIY handheld mini printer similar to PrintCube.
  • Make a module for a 3D printer that turns it into a CUPS-based 2D inkjet printer.
  • Make a printer that prints with edible ink on cookies, cakes, coffee cups, or whatever else you eat.
Even though these ideas are not new, making something out of it would still be an interesting adventure for a new experience. At first glance the task did not seem too difficult: I would take ready-made modules, which are on the market, put everything in one box and code it. Three easy steps!
Let's see what ready-made solutions for makers on the subject of printing already exist:
  1. Ink Shield GitHub - Open source solution. Not color. No longer available for purchase.
  2. Controlling an HP6602 printhead - Open source solution. Not in color. Can't buy an off-the-shelf solution as a module.
  3. MagicPaintBrush - Open source solution. Color!!! Can't buy an out-of-the-box solution as a module.
  4. Ytec3D Forum - Lots of information on reverse engineering various cartridges.
    All are not in color. Can't buy an off-the-shelf solution as a module.
The list could go on and on, but they all have one thing in common: at the moment, there are no ready-made modules for controlling a color printer cartridge. There is not even a monochrome print module that you could buy and use out of the box.
So this project was born.
Project goal
This project is an attempt to make a compact modular control unit for color/black print cartridges of an HP printer using a microcontroller.
It is based on the already tested in the MagicPaintBrush project by Sprite_tm's solution. The final result of the project: the realization of a working iron prototype in the form of a surface mount board, a 3D printer printable mount, and control software.
Cartridge pinout
Most of the description of the cartridge is taken from here and details of its reverse engineering can be read there. Here is a small part required to implement this project.
The picture shows the pinout of the inputs:
LabelDescriptionVoltage level
S3Clock line.16V
DCLKClock line.16V
D1Data line for the yellow color.9V
TS??????
D2Data line for the magenta color.9V
GNDGround.
PWRA - F3Print trigger line.16V
PWRB - F5Print trigger line.16V
S5Clock line.16V
D3Data line for the color cayan.9V
CSYNCData group switching line.9V
S1Clock line.16V
S4Clock line.16V
S2Clock line.16V
ID??????
To protect against burning out the nozzles in the cartridge it is necessary to limit the signal time on lines PWRA-F3(hereinafter F3) and PWRB-F5(hereinafter F5) to about 4-10 µs. Failure to do so may cause the nozzle heating resistors to malfunction.
Description of the designed PCB
The board is a converter of 5V input signal levels from the controller to the control signal levels of the cartridge.
Almost all of the circuit solutions were taken from the MagicPaintBrush project.
Circuit diagram:
Three blocks can be distinguished here:
1. Block of input voltage conversion from 5V to 9V and 16V.
2. The level shifter block of the control signals...
test-page-fill-data.srzip
Data dump from the printer
srzip - 1.06 MB - 01/12/2022 at 08:20
Download
The image that prints to acquire a dump from the printer
Portable Network Graphics (PNG) - 32.89 kB - 01/12/2022 at 08:13
Preview
Download
cartridge-scan-0.5M.stl
HP123 cartridge scanned model
sla - 23.84 MB - 07/28/2021 at 13:43
Download
mount-v2.1.stl
STL model of the mount for 3D printing
sla - 507.89 kB - 07/28/2021 at 13:40
Download
BOM_Cartridge_PCB.csv
PCB bill of materials
Comma-Separated Values - 4.13 kB - 07/20/2021 at 14:24
Download
View all 6 files
  • 2 × C1,C4 Capacitor 2.2uF SAMSUNG CL10A225KA8NNNC
  • 2 × C2,C3 Capacitor 10nF FH 0603B103K500NT
  • 4 × C5,C6,C7,C8 Capacitor 100nF YAGEO CC0603KRX7R9BB104
  • 1 × C9,C10,C11,C12 Capacitor 10nF SAMSUNG CL05B103KB5NNNC
  • 1 × CN1 IDC Connector Ckmtw 300R-14P
View all 17 components
View all 5 project logs
D Z wrote 12/18/2021 at 17:03 point
Hi! Have you abandoned the project?
Pavel Semenov wrote 12/18/2021 at 20:59 point
Hi! Project is not abandoned but I have been stalled it a bit. I think I'll go on it on the new year vacations.
D Z wrote 11/20/2021 at 23:44 point
very cool project, cant wait for final instructions!
Romina wrote 11/05/2021 at 09:53 point
Cool Project. Would you please update us on your recent progress? I am also really interested to build it.
Pavel Semenov wrote 12/18/2021 at 21:02 point
There are technical and time issues, but a working prototype is on the way.
sanketdhone wrote 11/04/2021 at 08:38 point
hey bro, can u post your recent progress I am really looking forward to build this!
Pavel Semenov wrote 12/18/2021 at 21:06 point
Hey dude, I can't say exactly when, since this is my first project, but I'll get it to a working version.
florian wrote 09/11/2021 at 15:41 point
Where u able to get it working? Would like to build myself one.
Pavel Semenov wrote 09/12/2021 at 14:21 point
@florian , thank you for your interest in this project. I am expecting to have a working version ready by mid of October, and I will publish the final instructions by the end of the month.
florian wrote 09/12/2021 at 14:43 point
Is the current PCB working that I can order one?
Pavel Semenov wrote 09/16/2021 at 14:37 point
@florian PCB still has some issues to fix. I am waiting for the revision with fixes from the manufacturer.
Anthony G wrote 08/29/2021 at 01:05 point
Depending how well the ink sticks to metal, I could see this as being tremendous for those making PCBs or metal jewelry at home using acid etching.  Use the printer cartridge to directly print on blank PCBs or pieces of brass, no need for laser printer toner transfer.
Pavel Semenov wrote 09/04/2021 at 12:10 point
@Anthony G , great idea to try. I don't know if the acid for etching is suitable in viscosity, thermal and other characteristics for the thermal print head of the HP cartridge. Will have to try with empty cartridges like this one:: https://aliexpress.ru/item/4001248043504.html
Neal wrote 02/24/2021 at 02:09 point
Cool project.  What library are you using to drive the PrintSpider board?
Pavel Semenov wrote 02/26/2021 at 12:08 point
I've not implemented any code yet, but I will adapt this realization https://github.com/Spritetm/printercart_simple in near future.
Gravis wrote 01/21/2021 at 19:15 point
Here's info on a similar print head: https://ytec3d.com/forum/viewtopic.php?f=8&t=28
Pavel Semenov wrote 01/22/2021 at 08:57 point
Thanks @Gravis . I've seen this project already. The problem is that HP45 cartridge used there is only a single color, so if you want full color printing solution you should combine at least three cartridges with it's own PCSs, connectors etc. I want a more simpler and cheap solution.
