Voron 2.4 inspired build using Ender 5 3D Printer frame profiles as a base and some parts laying around :)
Standard Tesselated Geometry - 4.68 MB - 02/14/2023 at 22:15
Standard Tesselated Geometry - 184.65 kB - 02/12/2023 at 03:08
Standard Tesselated Geometry - 79.18 kB - 01/30/2023 at 05:36
Standard Tesselated Geometry - 69.42 kB - 01/29/2023 at 18:29
url - 153.00 bytes - 01/28/2023 at 19:09
View all 40 files
View all 31 components
VorEnder 5 Buildplate/Heatbed sandwich:
1 Double sided Textured PEI Spring Steel 257x257mm
2 Magnetic rubber plate Energetic 260x260mm
3 Custom made 255x255x6mm glass base
4 260x300mm 468MP Double Sided Adhesive Transfer Tape
5 Creality 235x235x3mm Creality Ender 5 Aluminium Baseplate Heater P=220W 24 VDC
6 Transparent Silicone Rubber Sheet 260x260mm 1mm
Components > https://hackaday.io/project/177303/components
STL files > https://hackaday.io/project/177303/files
3x Self-lubricating radial spherical plain bearings GE5E
Tree z-axis 9mm Linear Rails : MGN9 L=350 KGT Linear Rail with MGN9-H block
Alignment MGN9 Linear Rail with 20x20 Aluminium Extructions V type Profile
3x MGN9 L=350 KGT Linear Rail with MGN9-H block
3 x Linear Rails: MGN9 L=350 KGT Linear Rail with MGN9-H block
Grease: SW-92SA Syntetic Grease
Blower Fan: Dual Ball Bearings GDSTIME 5015
Mod Repository: https://github.com/Greg191134/Voron/tree/master/Afterburner%20Optimisation/5015%20fan%20mod
VorEnder 5 3D Printer components list: https://hackaday.io/project/177303/components
2020 corner fitting angle aluminum 20 x 20 L connector bracket fastener match use 2020 industrial aluminum profile
STL files: VORON printhead for MicroSwiss hotend https://www.thingiverse.com/thing:4705446
Hotend: Trianglelab Swiss CR10
Creality Ender 5 Electronic controller box with FYSETC Spider V2.2 Motherboard 32Bit RRF Controller Board
Fysetc Spider brackets for Ender5 Controller Box - STL Files to print: https://hackaday.io/project/177303/files
PSU and IEC inlet module AC power socket: https://hackaday.io/project/177303/components
View all 25 project logs
Hello, I plan to start designing the VORENDER5 PLUS! Do you have assembly plans for the machine?Thank you for your work ... it's a good job ...
you ask for 2 times 200 M3, M5 what length???
Hey
Could you tell me the difference between front idler 3mm / normal?
Tryed to figure it out by uplaoad date...
Nice project by the way.
What length of belt was used on this project? 4x quantity x length?
Also with the screw amounts and corner brackets, are these for a brand new build even for the frame?
Dan
Shane Hooper
saarbastler
Mateo Miličević
Yes, delete it Cancel
You are about to report the project "VorEnder 5 Core XY 3D Printer", please tell us the reason.
