Rebuilding a laptop case in Lego and Lego compatible parts
Can apply the similar method with Acer swift 3 Linux model to run it with automate system?
Is this passible to adjust these cases on Dell Laptop? I want to it on my laptop to make the case screen cool.
Is there anything that can't be built with LEGO? I like the organic shape and color palette you ended up with on this one!
Thank you :) Will try to make it more firm. As well as I plan to rebuild the base of the case when it will crumble.
AVR
4KbShort
Mjnurney
devans013
Yes, delete it Cancel
You are about to report the project "Lego laptop case", please tell us the reason.
