How it started...
When I first got the idea of an all integrated 3D printer control board the only option available were the Raspberry Pi Compute Modules in SODimm format but I could not wrap my head around it so it was basically discarded before becoming a concept.
Then in 2019 I visited a workshop from ST about their all new STM32MPU1 and I was: hey, this could actually work. I even started designing the hardware from scratch and then somebody with the same idea came and killed the project because the MPU was not powerful enough to run OctoPrint. So it was postponed again.
First concept based on the STM32MPU1 name Progress R1
But than came the release of the Raspberry Pi Compute Module 4 with it´s all new formfactor and I was back on track because I knew it would not get better anytime soon. So I once again started working on it with a result I´m still absolutely amazed of.
First rendering of the board based on the CM4 - working title Progress R2
How it was designed
Working together closely with a few friends from the Voron community I figured out the necessary featureset to eradicate most compromises of the boards available today. With the biggest feat being the integrated Raspberry Pi which has almost all GPIO either used or broken out to connectors I put in everything a Voron could benefit of (cause I want one too) and everything I personally didn´t want to miss.
The schematic and board design were done completely in Autodesk Fusion360 within several weeks of sporadic latenight sessions. Several renderings were showcased to german 3D printing communities to check for feedback and additional ideas. Although being something I started for the sole purpose of doing it, I just couldn´t keep it a secret.
As the nature of the Compute Module requires the developer to handle the highspeed signals like HDMI or CSI by himself and break them out to connectors, impedance and length matching becomes crucial. To get the impedances under control I opted for a four layer pcb and choose the JLCPCB controlled impedance stackup as a design point. The JLC2313 stackup has a prepreg as thin as 0.1mm between the inner and outer copper layers allowing for really thin differential traces even at 90 Ohms impedance.
The power switch board was built as a separate PCB so I could get it manufactured with only two layers and with more copper on those layers (e.g. 2 oz. instead of 1) .
Somewhere during the layout and rendering phase I started to heavily dislike the working title of the board. Progress R2 just doesn´t sound good and neither does it written on a PCB, after quite a while of thinking about this I came up with the Sigmoid name and a 3 letter description of the board. The Sigmoid or S-function as eponym to the board acutally makes sense as well. With the Sigmoid function describing the traversal between to equilibrium values, the Sigmoid board basically traverses between the low-level mcu firmware and the high-level software on a Raspberry Pi.
What it can do
PrintingConnectivityMisceallaneous
7 TMC2209 Stepper DriverHDMI
Hardware Emergency-Stop circuit
4 Thermistor channels2x CSI for RaspicamUser controllable relay with NO and NC contacts
8 Endstop channels4 USB 2.0 Ports1 CAN bus channel
30A Power MosFETGigabit Ethernetexpansion connectors with UART, I2C and SPI
2 Extruder heater channelsWiFiCar fuses for system protection
3 Generic power switches
3 Fan channels with tachometer inputs
BLTouch connector
Software support
Generally speaking, everything is supported. I tested the connections required for the different Firmwares to the host prior to the PCB design with a Raspberry Pi 4 and a STM32F407 devboard. To flash the firmware  I use the integrated flash bootloader of the STM32 and added dedicated boot and reset lines between the MCU and the RPI. To support the STM32 port of RepRapFirmware and Duet Web Control, I also added an SPI bus connection between the MCU and the RPI.
RRF and DWC2 were actually the hardest ones to get working. The STM32 port is still pretty new and has some edges...
