Hackaday.io Hackaday.io
Sign up Log in
FumeFan
A rechargeable desktop fan to suck fumes away from you while soldering, replaceable activated carbon filter to remove some particulates.
sjm4306sjm4306
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
1.6k views
6 comments
23 followers
  • Description
  • Details
  • Files 9
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 6
View Gallery
Public Chat
1.6k
6
23
20
Team (2)
  • sjm4306sjm4306
  • felix-zFelix Z.
Join this project's team
completed project
hardware
fan soldering fumes filter diy project 3D printed
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 08/23/2021 and last updated 5 years ago.
Description
To start off, thanks to JLCPCB for sponsoring this project. JLCPCB Prototype for $2 (Any Color): https://jlcpcb.com/DYE I've really been meaning to make a little fan to sit right in front of me while soldering so I don't need a big room fan blowing everything across my bench. And if something is worth doing, it's worth way overdoing ... so let's throw a snazzy oled display, large lithium ion battery, custom 3d printed case and some fancy digital controls in the mix while we are at it!
Files
fanBOM.txt
Bill of Materials
plain - 12.37 kB - 09/15/2021 at 17:53
Download
Rear Case^FumeFan Assembly.STL
3D Printed Rear Wall
Standard Tesselated Geometry - 107.02 kB - 08/23/2021 at 17:16
Download
Sidewall^FumeFan Assembly.STL
3D Printed Sidewall
Standard Tesselated Geometry - 104.57 kB - 08/23/2021 at 17:16
Download
Front Case^FumeFan Assembly.STL
3D Printed Front
Standard Tesselated Geometry - 367.86 kB - 08/23/2021 at 17:16
Download
Filter Lid^FumeFan Assembly.STL
3D Printed Rear Filter Lid
Standard Tesselated Geometry - 136.70 kB - 08/23/2021 at 17:16
Download
View all 9 files
Project Logs
Collapse
  • 1st Prototype Design, Features, ... (and Flaws)
    sjm4306 • 08/23/2021 at 18:48 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
MennoLabs wrote 09/15/2021 at 16:02 • point
Could you add a seperate BOM?
If I click on BOM at the fan.sch link, I get a "currently unavailable" error.
I tried earlier and then it just said "uploading" indefinitely.
I can't get the BOM from the file, because Kicad is giving me an error.
My PCB's arrived today.
sjm4306 wrote 09/15/2021 at 17:53 • point
That would be because the pcb files are from Eagle, not Kicad. I've just exported the BOM as plaintext and added it to the files section.
MennoLabs wrote 09/16/2021 at 07:35 • point
Thanks a  lot!
Egor wrote 08/31/2021 at 21:13 • point
Nice project! But do you have a list of all the other parts besides the main logic board, like display, batteries n stuff?
sunny wrote 08/24/2021 at 15:45 • point
nice,what's the iron name?
sjm4306 wrote 08/24/2021 at 15:50 • point
It's an old radioshack digital temp controlled iron.
This project uses a 3D Printed Speaker "Cone" and Coil Bobbin as an audio exciter
Project Owner Contributor
3D Printed Audio Exciter
themixedsignalTheMixedSignal
Use Pimoroni InkypHAT hardware to make dynamic badges.
InkyPHAT: ePaper/eInk display for badges
charlie-lindahlCharlie Lindahl
A cost effective solder fume extractor for the home-gamer
openFume
andyAndy
Just a simple compact tetris clone using an ATTINY85 and a cheap OLED display.
pockeTETRIS
dombeefdombeef
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "FumeFan", please tell us the reason.
Send message
Remove Member
