Specifications
- No Compressor needed. Works with Co2 cartridges.
- Adjustable pressure 0-60 psi
- Adjustable timing from 50 millisecond up to trigger release.
- Ergonomic Injector hand tool
- Dimensions : 155 x 120 x 75 mm
- Weight : 770 gr (without packaging)
- Works with 12V DC adapter
Nuri Erginer
David McEwan
Andrey Kalmatskiy
Bud Bennett
Lithium ION
Hi Makers.
I have always loved and supported open source projects. But developing new devices as open source is getting harder and harder. I need your help to continue building tools for makers so I have to ask to pay a small amount for source files.
I hope you do not misunderstand my behavior. Be sure that, this money will be spent on funding new projects. Thank you in advance for your support.
Nuri
MakerStorage.
