Browsing the web, I found a fascinating niche activity. People have built homebrew CPUs/computers using just basic logic chips. And they actually worked, they did real computation. These ranged from trivial 4bit machines, that barely did anything, up to impressive 8 bit machines that run a customized version of Mimix. One crazy guy in England has used several thousand transistors to create a machine that takes up half a room. They look cool, sound great fun to build and I want in on the action.
But what to do? Well there seems no point in just copying what others have done. The fun is in designing your own unique project and the journey taking it from idea to working machine. Well it seems worthwhile to tread new ground, do something not done before. As far as I can tell, there is no homebrew 32bit machine (I don't count an FPGA implementation). And certainly, none seem to implement a fully specified existing instruction set architecture (ISA). This is something that must change.
A bit of research later and I have found the perfect ISA. There is relatively new open source 32bit RISC architecture called RISC-V that has been designed by researchers at UC Berkeley. Being a RISC design, it is relatively small in the number and complexity of the instructions that need implementing. This is important as any 32bit design is already going to be a big project, so lets not make it impossible by going for something like the CISC of the 80386!
Phil Wright
Implementing the subtraction operation requires a bit of extra work as we need to apply 2's compliment to the second of the two inputs. 2's compliment is the method used to invert the sign of a value. Converting a positive number like 5 into the negative version -5.
Testing shows that the logic is correct and the boards work as required. Although each board only worked on the third attempt at debugging the logic.
The comparator is going to be one of the slowest paths in the whole design. If you look at the worst path through both boards then it has 18 gates to get through. Yikes, good job I am not designing for speed!
Yann Guidon / YGDES
Brandon Reinhart
matseng
spudfishScott
Hey there,
I want to do this as my undergrad's final year project.Can you help me out?
