DIY ESP8266 Led Matrix Clock Kit
Entry-level DIY kit, designed as fun activity one can complete in one evening
Public Chat
Starting from
$20.00
andrey-malyshenko has 415 orders / 13reviews
Ships from Poland
This entry level Kit as quick and simple to-it-together activity for soldering education and just for fun. I designed it to assemble it together with my 6-years old son. End result is internet-synchronized digital clock, that helps my son to learn clocks and helps me sleep better, by hearing less of "Is it morning already, dad?" at 6 am.
  • Laser cut acrylic panel
    andriy.malyshenko04/25/2023 at 20:38 0 comments
    I love my clock ;) I have one just above my desk. Another one in kids bedroom. And another one at my mother's house. One thing that bothered me - absence of a case. I could make a 3D-printed case, but frankly always lacking time to do a good design. I can do some design in an evening, but to make a good design takes much more.
    I decided to take a shortcut and order a acrylic case for now. It quite cheap (when ordered in quantities) and it actually looks surprisingly good. Bonus: Now I can keep the clock on the top of my display.
  • 3 colors available
    andriy.malyshenko12/21/2022 at 14:17 0 comments
    Quick update, as requested by few Tindie customers, clock now available in 3 colors, blue being brightest one, and green most deem.
    And more importantly, it can play Game of Life, when it is not too busy being clock!
    Latest code as usual at gihub
View all 2 project logs
  • 1
    Start by checking all parts are present
    Make sure that all parts came in good shape and no apparent damage is done on the way.
  • 2
    Solder two 5-pin male headers to the screen
    Disconnect 2 edge led matrix modules from the screen. Be careful not to bend the pins, otherwise it would be a lot of dancing to put them back later on. Don't worry about orientation, they have markings on one side
  • 3
    Solder Wemos D1 module - headers to module first
    Solder headers to the Wemos D1 module. Long part of the header should be directed to the motherboard. Make sure to align them right, use motherboard as an aligning tool.
    Start with just one pin each side and double check your work. Then you can proceed to other pins
View all 10 instructions
Robert White wrote 05/09/2023 at 00:21 point
HI Andriy Thanks for the clock module I really love it. I have a question. I connected the clock to my wifi, have changed the time zone and rebuild/uploaded and it is displaying the correct localtime. I now need to move the clock to a new location with a different router. Rebuild/upload leaves the clock looking for the old ssid.I dont seem to be able to connect to the wifi config screen. How do I change the ssid? Thanks Regards Robert
Jim wrote 03/22/2023 at 13:55 point
I have built the kit and this is exactly what I was looking for to put in the ham shack. I have left it running for a while with the serial console attached. I am seeing a problem after 24 hours when it tries to get the next NTP update. When it tries to connect, it gets a "Soft WDT reset" (the watch dog timer kicks off). Looking around a bit, I think the issue might be because the WiFi link sets unused for so long. (There are a couple of different places where I saw reference to similar issues and this seemed to be one common theme.) It doesn't take long for it to reset, get the time, and start running (around 15 seconds based on the original time you see set and the time you see set after the the WDT kicks off). I was going to look at doing a single ping to the local gateway once a minute to see if that kind of network keep alive "heartbeat" would help. It isn't that big of a deal, but it is one of those things will be bother me if I don't dig into it a bit. :-)
andriy.malyshenko wrote 03/22/2023 at 14:28 point
Hi Jim, I have 3 of those clocks running around the clock and never had this issue. I would assume it would depend on your router and if it will accept device back into the network after long absence, as you described. For the quick fix, I'd set Wifi to be live all the time (if you not running of the batteries, that wouldn't make much difference for you anyway). Wonder it that would fix it.
Jim wrote 03/22/2023 at 20:20 point
The WiFi is up the whole time, but some notes I've seen say the ESP8266 has issues sometimes if it goes for a long period (hours) without using WiFi. I did watch things happen today: it freezes (because it was in the middle of scrolling the date just by coincidence) and then resets. On the console I see:
Local time: Tue Mar 21 18:20:49 2023
UTC time:   Tue Mar 21 18:20:49 2023
/* Everything above is from yesterday's connect, below starts 24 hours later */
*wm:AutoConnect
*wm:Connecting to SAVED AP: dogiron
*wm:connectTimeout not set, ESP waitForConnectResult...
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
Soft WDT reset
/* There is a stack dump, but the fact is the watch dog timer kicked, so it doesn't mean much. */
It resets after all of that and works just like when it was first powered up. There was only a one or two second pause once it started trying to connect and the WDT going off. That plus the message "connectTimeout not set" makes me wonder if the issue is that the connect timer might need to be longer. I'm going to see what happens if I shorten the period for it to try to sync to see if the problem persists (and would be a little easier to troubleshoot if it was happening once an hour instead of once a day).
andriy.malyshenko wrote 03/23/2023 at 09:59 point
Jim, feel free to submit a pull request if you manage to fix it.
