For now, updates are only being made to the github repository.
https://github.com/edson-acordi/4bit-microcomputer
Main Features:
- Implements a 4 bit CPU
- 2k x 16 Program Memory (up to 4k)
- 2k x 4 RAM (up to 4k)
- 4 Output Ports (16 outputs)
- 4 Input Ports (16 inputs)
- Single Cycle Instruction/RISC
- Harvard Architecture
- 3 execution modes:
- step by step
- 3MHz (precise time base)
- adjustable clock speed ( ≈ 1 Hz - 200 Hz)
- No MPU/MCU or complex chips
- No microcode
- Indirect addressing to facilitate the implementation of subroutines
- Program memory implemented with RAM to easy programming
- It accepts 300 and 600 mils memories (for those with old DIP versions)
- Supercapacitor or battery to keep the program in RAM (for low power version)
- It can be manually programmed by switches or via Arduino/Esp32
- Built with 74HCTxxx integrated circuits for low power consumption and compatibility with TTL circuits
- All parts are through-hole for easy assembly
- All control signals, registers and the program counter are available through the pin header connectors
- Dual layer Single board with 295.9mm x 196.9mm
MikroLeo Architecture
Note that some buffers are used to allow viewing the contents of registers at any time, since this project is mainly intended for educational purposes.
![](https://cdn.hackaday.io/images/2721291669208963028.png)
The MikroLeo Instruction Set
Although MikroLeo has only 20 instructions, using the AMODE bit (b14) and the modifier bits (b13:b12), it is possible to encode 64 combinations of instructions, as can be seen below.
![](https://cdn.hackaday.io/images/6161761669203678472.png)
Instruction Set explanation and examples
In binary, the Instruction Word is coded as,
![](https://cdn.hackaday.io/images/6379841669209100480.png)
ROMH (Most significant byte of program memory)
b15 | b14 | b13 | b12 | b11 | b10 | b9 | b8 |
MICRO2_IN | AMODE | MOD1 | MOD0 | MICRO3 | MICRO2 | MICRO1 | MICRO0 |
ROML (Least significant byte of program memory)
b7 | b6 | b5 | b4 | b3 | b2 | b1 | b0 |
MAddr3 | MAddr2 | MAddr1 | MAddr0 | Operand3 | Operand2 | Operand1 | Operand0 |
- Note: b15 = bit15 ... b0 = bit0
LDI - Load with Immediate
Description: Loads the operand value into a register.
Registers: ACC, RA, RB or RC
Operation: Register <─ Operand
Instruction Word | ROMH | Instruction | Affected Flags |
0x00xn | 0x00 | LDI ACC,n | ZF |
0x10xn | 0x10 | LDI RA,n | - |
0x20xn | 0x20 | LDI RB,n | - |
0x30xn | 0x30 | LDI RC,n | - |
Examples,
Instruction Word | Instruction | Comment |
0x0005 | LDI ACC,5 | Load ACC with operand |
0x1006 | LDI RA,6 | Load RA with operand |
0x2007 | LDI RB,7 | Load RB with operand |
0x300a | LDI RC,10 | Load ACC with operand |
The Instruction Word, for example, for LDI RA,6 is coded as,
0x1006 ┆┆┆└──> Least significant Nibble => Operand[b3:b0] = 6 ┆┆└───> Second Nibble => MAddr[b7:b4] = 0 ┆└────> Third Nibble => MICRO[b11:b8] = 0 └─────> Most significant Nibble => HiNB[b15:b12] = 1
Also, the instruction word (in binary) to be manually programmed into MikroLeo using physical switches is,
0001 0000 0000 0110 ┆ ┆ ┆ └─> Operand = 6 ┆ ┆ └──────> MAddr = 0 (For this instruction, it doesn't matter) ┆ └───────────> MICRO = 0 (OPCode) └────────────────> HiNB = 1 (MICRO2_IN = 0, AMODE = 0, MOD = 1)
NAND - bitwise Nand
Description: Performs the bitwise Nand operation between ACC with (Operand n, RA, RB or RAM).
The result is stored in ACC.
Operations:
ACC <─ ACC NAND Operand
ACC <─ ACC NAND Register
ACC <─ ACC NAND RAM
0x01xn | 0x01 | NAND ACC,n | ZF |
0x11x0 | 0x11 | NAND ACC,RA | ZF |
0x21xn | 0x21 | NAND ACC,RB | ZF |
0x31mn | 0x31 | NAND ACC,@RAM | ZF |
0x71xx | 0x71 | NAND ACC,@R | ZF |
Note:
The RAM address for @RAM is pointed by RC:MAddr:LAddr.
The RAM address for @R is pointed by RC:RB:RA.
The MAddr is represented by the letter "m".
Examples:
0x0105 | NAND ACC,5 | NAND operation between the accumulator and the operand and stores it in ACC |
0x1106 | NAND ACC,RA | NAND operation between the accumulator and register RA and stores it in ACC |
0x2107 | NAND ACC,RB | NAND operation between the accumulator and register RB and stores it in ACC |
0x310a | NAND ACC,@0x0a | NAND the contents of the RAM address with ACC and stores it in ACC. In this case, the RAM address = RC:0:a |
0x7100 | NAND ACC,@R | NAND the contents of the RAM address with ACC and stores it in... |
