For instance:
The 8031 is a "ROMless" version of the well-known 8051. To turn an 8051 into an 8031, just tie one pin to a voltage rail.
Then, the 8051 will ignore its internal ROM, and instead boot from an external one.
I was planning on starting this "project" with a more 'vintage' uC (e.g. the 6502-compatible I found at the bottom of the box) but this is the order of the pictures on my phone, and reorganizing with a thumb is a PITA, so I guess I'll start with this one.
And, actually, maybe it's a good thing, 'cause it shows this "technique" is still useful with more current eWaste, as well...
This was the interface board from a CD-ROM drive, as I recall. Most of the time, I've found that their chipsets are very closed secrets. But this one has a good ol' microcontroller.
This is a Hitachi (now Renasis) H8/3039 which is apparently a 16/32bit microcontroller.
The F in 64F3039 indicates that it's in-system-programmable, BUT: who has the time/energy to figure out that protocol, when you can just attach an E[E]PROM?
Actually, more-importantly, [yeah, I'm going about this documentation all backwards] is the underlying concept, here, that seems applicable to the wide number of assorted uCs one might encounter in old junk.
Anyhow, Wire-up the "mode" pins to Mode1 or Mode3, add a regular ol' external EEPROM, and whatever the heck is in the flash is completely irrelevant.
It'd make a heck of a lot more sense if I'd started with the 6502, 8031, and similar "fallback-mode" devices, instead. But I need to get this list documented for my own purposes...
At my first electronics gig, a contractor was developing with 8052 drop-in-compatibles. There was a pile of 8752's, as I recall, with windows, continuously cycling through the UV eraser for a day or two every couple weeks. When the updates were finally worked-out on the prototype system, they burnt OTP 8052s for the actual systems, about twenty of them.
Sounds great, right?
Well, after a week or so of testing all the systems working in unison, of course we found some things that needed to be changed, called in the contractor, and went through it all again. At least a few times.
Thankfully, about midway through the process, eraseable 8952s became affordable in our smallish quantities, so we only "wasted" probably around fourty to sixty OTP 8x52s.
I remember a cardboard coffin filled with these things, thinking "what on earth can be done with them now?!"
Fast-forward a couple years and I met a buddy who was in a similar situation at his workplace; they had piles of "burnt" One-time-programmable PICs waiting for trash-pickup.
He came up with something I'd thought utterly ridiculous at the time.
Apparently, as I recall, the PICs he scavenged had NOP=0x00. And, being that 'unburnt' bits were 1, he discovered he could essentially wipe-out all the old code and write whatever he wanted in the previously-unused portions of ROM.
Wow, smart!
Oh, but he was ridiculously-smarter than just that.
Eventually he got to the point of seeing which pre-existing op-codes he could modify (by changing 1 bits to 0), so he could do things like modify already-burnt IRQ tables and use far more of the ROM than was previously left 'unburnt'/empty.
I really thought him insane, at the time. But, I mean... THAT'S A HACK.
Somehow I hadn't pieced-together that the same might-could've been done with our burnt OTP 8052s... (Is NOP 0x00?), but I/we had also moved-on to the 8052-pin-compatible AVRs at that point, and reflashing was no problem. (nevermind /in-system/ programming!!!)
Fast-forward again, I started getting into the idea of learning a little about other CPU/uC architectures: MIPS due to some hackery with an old cable-modem, then on to MIPS-core PIC32s... I also dabbled in x86 with #Improbable AVR -> 8088 substitution for PC/XT , albeit from a completely different direction...
Started discovering these things really are all quite a bit more similar than I'd previously expected. There seem to be "camps" of folk into specific architectures, so I guess I mistakenly thought them to be very different, conceptually.
I started digging through my boxes of old scavenged PCBs to see what *other* processors I could learn about, and, repurpose. Many Z80s, a handful of others like an 8085, An 8031...
We're talking CPUs, here, not microcontrollers, because, well, who has time to learn not only a new architecture, but *also* a different programming technique for each one?
But then, when I stumbled on the 8031 I learned something incredible! The 8031, on that particular scavenged PCB, was accompanied (of course) by an EPROM... BUT, it wasn't a CPU, it was an MCU. Weird.
Then it got even weirder... The 8031 is, frankly, just an 8051 without an internal ROM. Wut?!
Nope, it got even weirder, in a good way...
Apparently "That Pin" that was always tied to some rail on our 8052s is tied to that rail for the sake of identifying whether you want your 8051/52 to act like an 8051/2 or... whether you want it /to use external ROM/, bypassing the internal one, essentially (if not /actually/) turning your 8051/52 into an 8031/2.
WUT?!
It basically means those 8051/8052 microcontrollers can be turned into 8-bit CPUs, with a few extra inbuilt peripherals.
And, apparently, the 8051/31 aren't the only ones...
Yahknow that weird microcontroller used for old keyboards, in old PCs? I think it's the 8048. Well, as-marked, it's a keyboard-controller....
I've been meaning to log my findings for a while now...
This, is that kind of energy-time, *not* introduction-writing-energy-time, so I'll update this later. But until then, check out the additional "logs" here!
This "project" (as opposed to this log, within this project) "started" with a random musing over at:
