RT Soldering pen
Soldering pen for Weller RT tips with OLED display
vlkvlk
Public Chat
Starting from
$60.00
vlk has 91 orders / 6 reviews
Ships from Prague, Czechia
Every hardware hacker need good soldering tool. My idea was to build own but with very specific qualities. On one side not so expensive, on second side high quality and also small with precise control and features. I found some projects where is used Weller soldering tips designed for WMRP soldering iron with standard 3.5mm jack and inside the tip is also thermocouple for sensing temperature. These tips are not so cheap but the quality is really great, especially for fine soldering. Hardware design is based on similar projects but with many modifications and improvements. Also my request was to make the hardware small as possible to fit into handle and capable to supply from hobbyist LiPO battery.Buy one on tindiy: https://www.tindie.com/products/vlk/rt-soldering-pen/
Features:
  • very compact - will fit into handle
  • display show status, preset and tip temperature, power, supply voltage, drop, ...
  • two buttons
  • automatic standby
  • sensing supply voltage and tip current
  • precise regulation with PID (PSD controller with some modifications)
  • supply voltage is from 5V to 15V (best is above 10V)
  • designed to supply from LIPO battery 2S (7.4V max is about 18W) or 3S (11.1V max is more than 40W)
  • calculating consumed Wh
  • heat-up in 5sec from 25 to 400°C (with 40W limit)
  • Idle current about 8mA
What is planed:
  • case
  • battery monitor (warn when battery need charge)
  • configuration editor for some constants from PSD controller, power limit, ....
  • open-source everything
Videos:
Portable Network Graphics (PNG) - 64.37 kB - 03/30/2017 at 19:45
Preview
Download
  • 1 × STM32F031 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × AD8551 Precise operational amplifier
  • 1 × ACS711 Hall effect current sensor
  • 1 × LMR14203 Power Management ICs / Switching Regulators and Controllers
  • 1 × OLED display 0.91" 128x32
View all 14 project logs
Petr Kounovsky wrote 04/05/2017 at 07:50 point
Great job, very sophisticated device. What about cover box ? Will you do it soon ? I'm curious.
sogseal wrote 03/30/2017 at 22:58 point
Epic! want one. Great job man, made my day!
jaromir.sukuba wrote 03/26/2017 at 19:49 point
Do you have some more details available? Like, PCB design, firmware.I have some RT tips and I'm interested in building controller for it - this one seems to be perfect fit.
electrobob wrote 03/26/2017 at 15:41 point
Really nice work. I think this is how the future of soldering irons should be, just get rid of the classical station box.
Why the accelerometer?
vlk wrote 03/26/2017 at 16:37 point
Thanks,
Accelerometer will be to wake up from stand-by
